power steering vacuum pressure switch and a smoking exhaust
Old 08-08-12, 08:52 PM
noobsense
noobsense's Avatar
Talking power steering vacuum pressure switch and a smoking exhaust
So my 1991 LS 400 has had a bad PS leak and also has been smoking from the exhaust quite a bit, turns out that the problems are connected! the vacuum lines that regulate the engine idle that run off of the PS unit have been letting mass amounts of fluid into the intake. Fouling plugs and causing havoc. Just thought that everyone would appreciate the heads up. problem solved!
Old 08-08-12, 09:43 PM
RA40
Super Moderator
RA40's Avatar
Welcome to Club Lexus. Yes, the PS leak at the ACV is common when the part is worn out. Glad you got it fixed.
Old 08-09-12, 08:52 AM
DonCorleone
DonCorleone's Avatar
Yes well known problem but good job on figuring it out yourself
jaxspot172
03-26-17 07:03 PM
Ls430Coy
02-19-17 08:13 AM
roccadet
Performance & Maintenance
02-20-12 10:51 PM
Bon
01-01-11 08:39 AM
UR2klose
02-12-09 04:02 PM
Quick Reply: power steering vacuum pressure switch and a smoking exhaust
