Unknown pulley and wire. what is it?
Old 11-18-02, 11:33 PM
Lvangundy
Guest
Posts: n/a
Default Unknown pulley and wire. what is it?
I saw this little pulley and it's wire cable, but I can't pull it nor push it. Anyone know what it is?
Old 11-18-02, 11:34 PM
Lvangundy
Guest
Posts: n/a
Another shot
Old 11-19-02, 10:20 AM
mlevk
mlevk's Avatar
Looks like the heater control valve, electronic type
vs manual for most other cars. It controls the amount
of coolant passing thru the heater core thus controlling the
temperature. I'd bet if you unplug it you won't have heat or
too much heat.
But I advise against it, if you crank up the temperature the
position of the lever should move.
Old 11-19-02, 10:31 AM
Lexozz
Lexozz's Avatar
Mlevk is correct! Don't disconnect, that valve is filled with antifreeze to heat up the cabin. It's cool seeing it move, I hit the temp switch and run to the engine bay just to amuse myself..kinda feel like a kid...
Old 11-19-02, 11:26 AM
Lvangundy
Guest
Posts: n/a
OHHH
That's what that noise is inside when you adjust the temperature up or down..you can hear a little motor moving if it's really quiet outside.
Old 11-19-02, 02:49 PM
healerhand
healerhand's Avatar
Hey Lee,
Too bad we missed each other at Signal Auto. Anyway, my turbo inlet hose goes around it. I think it has to do with temperature control, most likely heat.
Old 11-20-02, 11:14 AM
mlevk
mlevk's Avatar
I guess I should be a little more careful in describing things.
"Disconnect" the "HARNESS WIRES" controlling it.
Yes , Lexozz is right , that if you fully disconnect it the
anti-freeze would shoot out.
98sc300
Performance & Maintenance
03-17-13 07:13 PM
treeman
01-24-10 11:51 AM
bigdogg49
GS - 1st Gen (1993-1997)
17
12-18-08 09:27 AM
turbosix
01-07-08 12:14 PM
Roy Munson
02-27-06 03:53 PM
Quick Reply: Unknown pulley and wire. what is it?
