It has FINALLY happened! I just became a Lexus owner - 99 LS400
Hey chaps,
I am so proud to be an official member of the Lexus owners club. I picked up my 1999 pearl white LS4 two days ago and I look forward to many years and even more miles of peaceful serenity behind the wheel. It almost didn't happen. I was considering a Mercedes c-class first because I love German cars and I've always had a soft spot in my heart for Benzs but my rational side won me over and I bought the LS. It has 104k, gray interior, nakamichi sound, but no sunroof or heated seats.
Anyway, I've averaged 22.5 mpg on the first tank so I'm happy with that. What I'm not happy with are the oem wheel styles, lack of exhaust noise, and body float/roll.
So my purpose of this thread is to make my official "formal" introduction and to bounce some ideas off of you seasoned Lexus club members.
1. Wheels - this is easy, I already perused the numerous threads about this subject and I am aware of which Lexus wheels fit other Lexus cars so I don't need much input here.
2. Exhaust - the oem sound is nice and smooth which is what I like and don't want to change. I just want to turn up the volume a bit without having huge pipes sticking out from under my rear bumper. So I want the same smooth exhaust note with a little more volume while keeping the stock look if possible. If it isn't, just say so.
3. Body roll/float - this is what I want to change the most but it is what confuses me most. First of all, what are coilovers and what do they do? Second, let me explain what I hope to keep about the Lexus ride and what I want to get rid of. I want to keep the smoothness with which the LS absorbs the road imperfections. But I want lose the subsequent up and down bounce which follows. To explain it another way; you have tempurpedic memory foam mattress and a waterbed mattress. Both will absorb impacts well but the tempurpedic will stay stable and composed after the impact while the waterbed will bounce and take its time to settle down after the impact. The tempurpedic is likened unto the GS (or a Mercedes) and the waterbed is likened unto the LS in terms of ride quality. Is there any way to keep the excellent bump absorption without having the unwanted seasickness? I read the Bilstein makes for a happy medium so how much are they and are struts all that need changing to achieve the desired result?
What would other options be?
Btw, I had Lexus do a pre-purchase inspection before I bought it and they said the suspension and steering are in great shape.
Super Moderator
Congrats on the LS.
For the exhaust:
http://sr1.clublexus.com/forums/ls40...arts-pics.html
https://www.clublexus.com/forums/ls4...o-talk-in.html
If the car is floating over bumps, it is highly likely the shocks are dead and due for replacement. Each of the Bilstein HD's will get you about $130. Add in about $200 for install and $75 for an alignment. If you can DIY the install you save some $. The BIlstein has 2 perch settings so if you want about a 1/2" drop on the stock springs, you can use the lower mount setting.
For the exhaust:
It is doubtful that LS shocks would be worn out after only 104K. I've bought one LS400 new in 1990 and my current 2000 LS used at 38,000 in 2003 and they were just as "floaty" when I bought them as when I sold the 90 LS at 183,500 miles and my 2000 LS400 is now at 156,000 miles.
Go test drive a new $90,000 LS460L with air suspension as I did last fall if you want to experience a "floaty" suspension. My aging 00 LS400 feels way "tighter" and much more fun to drive than that barge.
RockAuto has some of the best deals I can find on the parts.
Well I don't know the condition of the roads my car traveled on for the first third of it's life. It is originally from Hawaii and was then shipped over to California before being brought to Utah six months ago.
I would not be surprised if Hawaii faces similar issue as we do in PR. Tropical climates present a lot of problems. If you go out to your car and use you weight to push down on the front left and/or right side does she press down and by how much by your estimation? Can you rock the front end by doing what I mentioned. If so, you need struts. RockAuto is $569.75 shipped for 4 struts, 4 mounts, and 4 strut boots. I know because I need to do this sometime soon.
Other recommendations are:
- Start the drain and refill procedure on your trans fluid. 2 quarts are in the trans pan. Repeat every 6 months to a year.
- Clean throttle body
- Change differential fluid
- Has the car had the major timing belt water pump service? Pretty expensive but very important. About $1,200.00 parts and labor.
- new air and cabin filter
The LS's are not the cheapest to own but the longevity will pay you back in the long run if you do things right. You can easily pass 300k miles on a properly maintained LS 400. It's all about preventive maintenance.
True. So if I want to keep the same ride height, it sounds like my only options would be OEM struts or the Bilsteins. RA40 said the Bilsteins would run $130 each; how much are OEM units?
Lexus of San Juan wanted nearly $450.00 per strut for OEM (parts only). What a joke... KYB, again, is OEM. Don't forget you need to do the strut mounts as well. Don't replace the struts without doing the mounts!
BahHumBug
Hey chaps,
2- RA40's got you covered, but an exhaust resonator delete sounds up your alley, it involves removing the 2nd to last pair of mufflers and replacing them with pipe the same diameter as OEM to the last set of mufflers.
3- mild improvements can be had with bilstein shocks and OEM springs, but the oem springs are VERY soft, so if you want that firmed up ride you won't get it from them. If you don't mind a moderate amount of lowering, the coilover best known for giving a near-oem ride while allowing you to drop the car a little and greatly firm up the handling would be the Tein CS. The downside is that they can't get you very low, and are not cheap (~$1,500 new)`
Okay folks, here is my plan:
Resonator delete for the exhaust
Bilstein HD struts
And these wheels http://www.netcarshow.com/lexus/2004...llpaper_12.htm
I have nothing but good things to say about owning a Lexus so far. I'm taking me car in on Saturday morning to have the transmission fluid changed and the brake fluid replaced since it was recommended. Out the door it should cost me about $300 which is dirt cheap compared to the $450 i was charged just for the tranny fluid on my BMW. The best thing is that, even though the service only takes about an hour, the dealer is giving me a free loaner so my partner and I don't have to delay our day trip to Bear Lake.
Bilstein HD struts
