I have this light on.1995
Old 08-15-12, 04:07 AM
blkstealthpaid4
blkstealthpaid4's Avatar
Default I have this light on.1995
This circular light comes on after I bust my *** and change both wheel bearings in the front.Is this light related to the speed sensor that is held by one 10 mm bolt that screws into the wheel bearing housing or is this another sensor gone bad?
Old 08-15-12, 04:08 AM
blkstealthpaid4
Please disregard my high mileage on this 95.
Old 08-15-12, 04:44 AM
billydpowe
billydpowe's Avatar
It's your brake pad warning light
Old 08-15-12, 04:51 AM
blkstealthpaid4
I had never touched the rear and this light came on.So I am thinking the front is the problem.The front pads were good and I remember seeing the sensor being inside the caliper.I will go check again but where is that sensor coming from and into the top of the caliper.
Old 08-15-12, 05:16 AM
akitomk3
akitomk3's Avatar
That light indicates that you pads are low and need replacing. That just came one recently? OR just now, well, check the front/ rear sensor, you can buy new sensors so next time your pads are low you'll know or just join the 2 wires together to remove the light. I check my own brakes and don't need any kind of light to tell me that my brakes are low so I just joined the 2 wires back together. The wire acts as a circuit and will trip the light on the dash if your pads are too low and eventually ate into the wire/ sensor itself.
Old 08-15-12, 05:47 AM
kyddo112
kyddo112's Avatar
yeah new sensors are pretty pricey. i did the same thing and just jumped the connector after doing my brake pads. sewell has the indicator for $48 each if you're registered as a clublexus member. if not, its $66
Old 08-15-12, 07:11 AM
ecuwil
ecuwil's Avatar
I experienced a similar problem after changing my brakes and rotors. Apparently I damaged the brake pad wear sensor. Picked up a replacement from RockAuto for $28.
http://www.rockauto.com/catalog/raframecatalog.php
Old 08-15-12, 10:40 AM
blkstealthpaid4
Which part do you guys bridge?.Is it towards the end of the cable or before the sensor connector itself?
Old 08-15-12, 02:25 PM
west709
west709's Avatar
yea its just the sensor i did my brakes and broke the sensor now that light is on all the time. i heard u can take the wires of the sensor and touch them together to trick the light off. havent tried it yet i will let you know if it works
Old 08-15-12, 03:07 PM
timmy0tool
timmy0tool's Avatar
check this out for the sensor fix, with pictures!
https://www.clublexus.com/forums/ls4...fix-ucf20.html
holy high mileage, so happy she is still going strong!
Old 08-20-12, 04:32 PM
west709
west709's Avatar
Cut the wire as twist or solder them together it will turn the light off if u do not want to change the sensor. I just did mine 30min ago and it turned the light off
Old 08-20-12, 04:38 PM
west709
west709's Avatar
Caniac14
09-30-14 01:48 PM
pfcrayb
03-14-14 12:11 AM
MattLS400
28
02-21-14 04:25 PM
renatodato
02-24-10 10:35 AM
Banshee365
01-22-10 01:19 AM
Quick Reply: I have this light on.1995
