Temp Gauge Still Not working...HHHEEELLPPP!
Old 08-29-12, 08:24 PM
GreenUCF20
GreenUCF20's Avatar
Default Temp Gauge Still Not working...HHHEEELLPPP!
OK so i had my coolant temp sensors changed but my temp gauge still doesnt move its just all the way down. Never had a problem with overheating or anything but looks like it may be the cluster. Everything else works fine. All advice is welcome.
P.S. I love this car its in great condition inside out how much is it to fix the cluster???
Old 08-29-12, 10:03 PM
Lavrishevo
Lavrishevo's Avatar
$150 - $250 would be a good estimate. DNA Speedometers in Tampa, FL were pretty good when I called them in regards to my sticky speedometer.
Old 08-30-12, 04:38 PM
GreenUCF20
GreenUCF20's Avatar
Thanks I appreciate it!
Old 08-30-12, 04:46 PM
GreenUCF20
GreenUCF20's Avatar
I love the quote from Proverbs too...
Old 08-31-12, 09:32 PM
GreenUCF20
GreenUCF20's Avatar
Found a spot closer to my house called BBA Remanufacturers in Taunton Mass
Old 09-01-12, 10:00 AM
SkulCracka
SkulCracka's Avatar
which ones did you change? the green one passenger side just to the right of the passenger distributor? if so that was the wrong one. that is the ECU temp sensor. its the smaller one just behind that.
Old 09-01-12, 10:51 AM
LS400BOY
LS400BOY's Avatar
Could it be a sticking thermastat??
Old 09-02-12, 08:41 AM
Lavrishevo
Lavrishevo's Avatar
No, a thermostat stuck open just prolonges the warmup time of the engine.
Old 09-02-12, 08:19 PM
dc893
dc893's Avatar
You can find used clusters for around $100. My tach was broken when i got my car and i just ordered one off ebay. for about $100. Maybe worth a try if you can spare the cash.
Old 09-03-12, 04:58 PM
Lexinky
Lexinky's Avatar
Default Scangauge
Maybe a Scangauge ( http://www.scangauge.com/ ). It willl tell you your engine temperature and do alot more. BUT your Ls must have OBD2
Old 09-03-12, 05:21 PM
Ls400RR
Ls400RR's Avatar
I have seen a eBay listing for service to your instrument cluster. You ship it to them and they repair all the major problems and more for about 60.00$. I need to do this and might give it a shot. My cluster is all out of whack,
Old 09-03-12, 07:38 PM
TaninAuto
Sponsor
TaninAuto's Avatar
I can fix your problem for cheaper than any other quote you get. I work on all Lexus clusters, climate units, radios, etc 1990-present
Shoot me a PM.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
BigD
17
12-03-15 02:19 PM
GreenUCF20
08-19-12 04:46 PM
stockhatch
Performance & Maintenance
02-01-12 09:57 AM
Nolamatt
SC- 1st Gen (1992-2000)
08-14-11 03:57 PM
Samuel
10-16-01 09:01 AM
Quick Reply: Temp Gauge Still Not working...HHHEEELLPPP!
