why do i still feel like theres air in my brakes??
Old 09-09-12, 12:30 PM
  #31
python
python's Avatar
wow..first question asked should have been...describe the problem. telling us it feels like air in the lines isnt telling us anything because what u think is an air in the lines symptom,might not be. if ur brake fluid drained from the master cylinder and the car was running,or even with the car in the on position...u probably ruined ur abs unit. you said u caught it at the last second..im not too sure u actually did
Old 09-09-12, 05:04 PM
  #32
LS400BOY
LS400BOY's Avatar
no it wasnt leaking from the master cylinder,i noticed it leaking from the cylinder in the brake caliper where it pushes the brakes,the cylinder had popped out of place because the brake pad had popped out of place while driving causing it to just push its way out then started to leak from there,, the reaason that happend because the bolts that holds it in place wasnt tight and came out,im guessing previouse owner didnt do a good job at it
Old 09-09-12, 06:29 PM
  #33
python
python's Avatar
ur missing the point..if the fluid runs dry in the master cylinder,no matter what the reason or cause and u have the car running or in the on position u most likely ruined ur abs unit
take it to a shop if u continue to have issues
Old 09-09-12, 06:35 PM
  #34
LS400BOY
LS400BOY's Avatar
the master cylinder didnt run dry
Old 09-10-12, 05:32 AM
  #35
j2b4o
j2b4o's Avatar
Bleed the master and the abs unit as described in the shop manual. I don't know the procedure on these cars or I would tell you. It's probably air in the master somewhere or the ABS unit, if you in fact did bleed each caliper correctly and in order. You lost some major fluid and I'd be surprised if air didnt work it's way up the system while driving around with no pad and the piston fully extended and than gone.
Old 09-10-12, 09:26 AM
  #36
LS400BOY
LS400BOY's Avatar
ok great,so theres a certain order to bleed them??? so bleed the abs to you said
Old 09-10-12, 11:27 AM
  #37
RA010623
RA010623's Avatar
are you sure the caliper and piston was reinstalled correct? is there signs of fluid leaking from the piston?
Old 09-10-12, 02:33 PM
  #38
LS400BOY
LS400BOY's Avatar
YES i bought a brand new caliper from the parts store along with brake pads
Old 09-10-12, 02:56 PM
  #39
j2b4o
j2b4o's Avatar
Usually you just have to start with the furthest corner from the master and than the next furthest and so on. That is just a normal rule of thumb there may be an exact order for the LS but it's likely what I said.
Old 09-10-12, 03:45 PM
  #40
LS400BOY
LS400BOY's Avatar
hey thanks didnt know that,im going to try to do this hoping tomarrow after work to blled it the proper way,i slso checked for the master cylinder for leaks and theres nothing,all the hoses seem fine to but havent seen anything on how to bleed the abs??
Old 09-11-12, 10:08 PM
  #41
LS400BOY
LS400BOY's Avatar
Any help on abs??
Old 09-12-12, 08:12 AM
  #42
python
python's Avatar
i smell impending disaster
http://stoptech.com/technical-suppor...-brake-systems
Old 09-12-12, 10:21 AM
  #43
LS400BOY
LS400BOY's Avatar
Shoot i aint going to do it yet lol im going to bleed the brakes in the order it needs to then go from there lol
Old 09-14-12, 05:42 PM
  #44
deanshark
deanshark's Avatar
Originally Posted by LS400BOY
yes i bleed the brakes with the motor runing, i did each valve 4-5 times,the pedal is soft at first press but after that it tightens up
Bleed the brakes with the engine off. I think I know what you're saying by "slipping" (I think). When you press the pedal, does the pedal gradually go to the floor? Does it feel stiffer if you press, release, and press the pedal again? If yes, then yes, you have air in the lines.
Just so you're doing it right. (bleeding) Have someone pump the brake pedal 3 times and hold the pedal down, you open the bleeder valve on each caliper until the pedal goes to the floor, then you close the valve, THEN he releases the pedal. Repeat until just fluid comes out the valve, no air bubbles. Just figured I would say that b/c it sounds like you're not doing it right.
If the caliper piston came out and you were still using the brakes then you pulled a hell of alot of air in there.
Old 09-14-12, 07:58 PM
  #45
LS400BOY
LS400BOY's Avatar
Thanks for the response,im off tomarrow so im going to be foing this for sure,ill let you guys knows how it goes,thanks much
Quick Reply: why do i still feel like theres air in my brakes??
