All my crazy Lexus issues SOLVED!! (ECU-leaking capacitor)
Old 07-18-24, 04:14 AM
  #1951
Yamae
Forum Moderator
Yamae's Avatar
I have never heard of the ECU P/N 89661-250TR and it may be a special one and not a standard one. As you see the list below, the only thing I can say is that the smallest value is a 10uF among other all LS400 families. Also voltage 63V capacitors are all 47uF from from 90-00 all models. I can not guarantee but your assumption is probably correct.
1990-92 LS400 needs 10 or 11 caps as follows:
Qty. 3 of 10μF - 50v
Qty. 2 of 15μF - 35v
Qty. 3 of 47μF - 63v
Qty. 2 of 100μF - 10v
Qty. 1 of 220μF - 16v
1993-94 LS400 needs 8 caps as follows:
Qty. 2 of 10μF - 50v
Qty. 1 of 47μF - 63v
1995-97 LS400 needs 6 caps as follows:
Qty. 2 of 10uF - 50v
Qty. 1 of 47uF - 63v
Qty. 2 of 100uF - 10v
Qty. 1 of 220uF - 16v
1998-2000 LS400 needs 11 caps as follows:
Qty. 2 of 10μF - 50V
Qty. 3 of 47μF - 63V
Qty. 2 of 100μF - 10V
Qty. 1 of 220μF - 16V
Qty. 1 of 33μF - 35V
Qty. 1 of 47μF - 25V (special BP capacitor) - high reliability capacitor, replacement recommended but not critical
Qty. 1 of 330μF - 35V - high reliability capacitor, replacement recommended but not critical
Old 07-18-24, 04:27 AM
  #1952
Meech
5th Gear
Meech's Avatar
Thanks again Yamae. Reassuring that you think the same. I will let you know how i get on when i have swapped the caps.
Old 07-28-24, 06:02 PM
  #1953
Oursuda1lab
3rd Gear
Oursuda1lab's Avatar
Default Random misfire/Cylinder 2
I think I’m having the notorious ECU problem with my ‘96 LS 400. Runs fine, no starting issues, but sulfur smell when warming up in garage. Then today received the check engine light and had some rough idling at the stoplight. Plugged in my OBD2 tool and had the P0300&P0302 fault codes.
Later it ran fine…?
Should I have the ECU rebuilt or buy one from Flagship 1 ?
any suggestions would be greatly appreciated.
Steve
Old 08-23-24, 04:58 AM
  #1954
charlieee3
1st Gear
charlieee3's Avatar
Hi all, my 94 SC400 has been recently having problems with shifting, so I put car in diagnostic mode and got error code ECT 62 (Shift solenoid 1 valve). So I would only get gear 3 and overdrive in drive position, but could get 1st and 2nd by starting in low gear. I replaced the shift solenoids and the problem went away and shifted well for about a day until the error code came back on. The next step in the repair manual was to check the wiring harness, so I did a continuity test to the solenoid pin on harness that goes to ECU and wiggled the cable around a lot and determined the wiring harness was fine, so the last thing in the repair manual was to check and replace ECU. So, I've opened it up and I've put some photos below.
The only thing I can see that looks bad is the two capacitors in the picture below, what do you guys reckon?
Thanks in advance!
Old 08-23-24, 06:33 AM
  #1955
Yamae
Forum Moderator
Yamae's Avatar
Thanks in advance!
What a terrible ECU rebuilt job was done. Traces are not properly repaired. Chinese capacitors Suntan are used. I'd say their capacitors have bad reputations as is posted here. I'd simply use an ECU refurbished by Denso.
Old 08-23-24, 08:00 PM
  #1956
TySoCal
8th Gear
TySoCal's Avatar
If that was my ECU I'd replace ALL electrolytic capacitors with ones from a reputable manufacturer (e.g. Nichicon) bought from a reputable distributor (e.g. Mouser, DigiKey). I'd also repair any visibly cut traces. This involves about $10 worth of parts and an hour or two of work, If you are not comfortable with doing PCB repairs including soldering then I suppose buying a reconditioned ECU (if available?) from Denso, as suggested by Yamae above, is a good but expensive idea.
I can't guarantee that fixing the ECU will solve your shifting problem but I can tell you that when I recapped mine a few years ago it solved several problems.
Old 08-26-24, 04:32 AM
  #1957
Meech
5th Gear
Meech's Avatar
Later it ran fine…?
Steve
Hi Steve
I would 100% swap the capacitors but make sure you use the ones recommended in the thread. Nothing to lose. Not sure if you feel confident enough to do it yourself but it is not too difficult if you follow the advice in here. Solved 99% of my problems.
Old 08-26-24, 04:46 AM
  #1958
Meech
5th Gear
Meech's Avatar
Default Update
Originally Posted by Meech
Thanks Yamae.
I did get a code for the TRAC but have forgotten what it was now as my attention was on the non start problem at the time.
I have ordered and am waiting for the capacitors from Mouser at the moment, when they arrive I will replace and se what happens then.
Would you agree that the 0.47uf capacitor that was replaced was most likely a mistake for a 47uf?
I am beat about the ecu part number also. I have tried and tried to research that number but nothing shows. really weird.
Hi. First off, great thread and unreal info, so helpful. Hope someone may be able to give me some direction on my car, well my son's car but I do majority of the work on it (ex-mechanic and auto electrician).
We have a LS400 build date on plate is Sept 1994 and located in Australia. Had the car 18 months now and when we had her she seemed to drive fine, couple of lights flashing such as engine light when first started and TRAC light flashing constantly. She needed some other work and so wasn't run much at all. When we got round to running her again she first started to cut out and not start. It would try but die. Seeing as there wasn't much fuel I guessed it must have run out. Put fuel in, cough and splutter and it went but shuddering etc. so thought dirt in the tank been picked up so cleaned tank out.
Car did not run for months then started to use it but it would misfire, backfire and then over fuel and smoke from the exhaust. I fell across this thread (thank you lord) so pulled the ecu and had a look inside and saw that it had already had capacitors changed. I thought I may as well swap them again BUT didn't read close enough so got some random capacitors from the local Jaycar and swapped whatever they had of the equivalent caps. Put it back together and VROOM... she drove beautifully (still TRAC light on though). Drove it for about 6 km then she died and wouldn't start. Left it a couple of hours and she drove back home and died again just before the driveway.
So, I have a few possibilities and a concern on the actual ECU itself.
1) Cheap caps need replacing with quality ones, Digi-Key have all I need and are in my basket as I speak. 9 caps in total in this ECU.
2) One of the caps has not been replaced previously, still has a Nichicon 15uf 35v PF(M) installed so will swap.
3) One of the caps that has already been replaced is a 0.47uf 63v which I am thinking was mistakenly used instead of a 47uf 63v.
4) Which is a big one, my ECU part number is nothing like any of the ones mentioned (that I can see in any post) it is 89661 - 250TR. Does anyone know if this is correct or if not what this unit is from? I tried Googling but nothing really came up. Car ran well for a while when I swapped the caps before but then broke down (possible cheap or wrong caps) so thinking if I put quality caps in it may run ok but wondering if this may be the TRAC light problem due to incompatibility.
Any help would be great, thanks in advance.
So, I received my capacitors from Mouser (about AU$4.00 and AU$20 delivery) and I swapped all 9 capacitors. 2 were original never been swapped, 1 was a 0.47uf instead of a 47uf and the others were the generic ones I got from the local electronics stores and swapped a few weeks ago. Runs beautifully, problem seem to be solved. I reckon it was the generic caps I bought (possibly the wrong one also didn't help) which reinforces the fact you should only get the ones recommended here and not just any old ones. The others seem to work to begin with, stopped all the wierd stuff it was doing but the car only ran for about 6km before it broke down and wouldn't start. Left it for a while and it ran again for another 6km. Fine now with the good caps. Still got TRC light flashing but haven't looked into that further yet.
Old 09-28-24, 02:50 PM
  #1959
MK3SupraSC400
1st Gear
MK3SupraSC400's Avatar
Default Stuffed ECU Repair?
Howdy LScowboyLS,
I have a new to me 93 SC400 which I believe the ECU has gone bad. It has always run a bit rough, then occasionally sounds like it has a 2-step tune and shakes the whole car. The check engine light has never worked so I couldn't pull codes. I suspected the ecu, but it has a Tanin Auto Electronix rebuilt sticker on it. I emailed him and he said his warranty was not transferrable to a new owner. I opened it up (following your advice on this thread) and it looked good. I diagnosed and fixed other issues, then it started to die at idle, but still ran on throttle. I followed the Lexus service manual to fix the MIL so I can get codes. I found the ecu is not grounding the MIL for key on or to flash codes.
I think this means the ecu is broken. Is it possible to repair this ecu? Will new (High Quality) caps potentially fix it?
I inspected the board again and included in the pictures are potential problem spots on the bottom board. (R867 and R160)
Old 09-29-24, 09:10 AM
  #1960
Yamae
Forum Moderator
Yamae's Avatar
Originally Posted by MK3SupraSC400
Howdy LScowboyLS,
I need to inform you 2 items.
1, LScowboyLS had gone about a decade ago and never came back.
2, I can recognize the leaked QAS liquid on the printed circuit board and traces are damaged in addition to some failed parts. I don't know those are now repairable or not without analyzing them myself. The quickest way to judge would be to use a good working one.
Quick Reply: All my crazy Lexus issues SOLVED!! (ECU-leaking capacitor)
