All my crazy Lexus issues SOLVED!! (ECU-leaking capacitor)
#78
they have this thing where you add to my wishlist from any dealer, website, hell i got a 11k motorcycle on my wishlist lol but anyways i hate typing in visa number and info over and over so i use it and or i believe you can use paypal
this is the wishlist thing you just put it in your favorites bar or whatever anyways just trying to make it easier on others.
#80
Tech Info Resource
Interesting thread. I had my ECM in my Supra (G-Force modded with daughterboards, raised rev limit, speed limiter and boost cut disabled) suddenly start acting up - Vf was stuck at +5.0v and it was running pig rich all the time - and I could never find a reason why. I put the OEM ECM back in, and it ran fine, passed smog, Vf was normal. I looked in the ECM and it has the Nichicon caps in it. Only four of them but if I can get that ECM to work again, I'll be very happy!
I installed a GReddy BCC in the OEM ECM, so working on it is no big deal. I was a bench electronics tech in the Air Force, so soldering is pretty simple - got a few spools of 37/63 eutectic in my tool box too...
The knowledge in this thread needs a wider audience!
#82
Hello everybody, here a post from another dutch guy.
I own a Toyota celsior 1995, and after some day that i had the car, the idle seems to be going wrong. The car falls out after some time.
After about 45min on the highway on cruisecontrol (max 110km/h japanse import RHD) the engine is good on temp, Then i get off the highway en stop for a traffic ligt, the car sometimes falls out or very low rpm (150 to 200RPM) But if i then turn on the AC or i restart the car all seems to be ok again. It seems to be like a vacuum problem, but can it also be in the ECU?
The car had 112.568 Real KM'S
Year 1995
V8, has traction control.
I check the throttlebody inside, and it looked pretty clean (not weird because so low km's)
And where could i find the ECM? (ecu)
Also sometimes the airbag lights flashes on the dash, just for a second.
Does anybody has suggestions for solving the problems?
Thanks,
Poika.
![](http://imageshack.us/a/img211/9262/img0662y.th.jpg)
![](http://imageshack.us/a/img16/8787/img0664h.th.jpg)
Year 1995
Thanks,
Poika.
![](http://imageshack.us/a/img811/7018/img0656eq.th.jpg)
#84
Thanks,
Poika.
Thanks,
Poika.
http://celsiorup.com/custom20/2015_F...d_changer3.htm
Regarding the fall out or very low rpm problem after the high speed run, I have some experience.
Check your ECU ID number. 89661-50240 and 89661-50241 tend to cause your type of stall problem after high speed run when the car is aged. This is a known issue among JDM and USM 95 models.
moinhaider (06-17-20)
#85
Thank you for your reply ! I apreciate it.
But how is this possible with 112.456 km's??? Its toyota quality right?
Today its very rainy in Holland, so i could not check the ECU
But: If i have one of those 'bad' ecu's, how can i re-program the ecu? If not re-program, where could i find a good ECU what solves the idle?
And i find it very strange that when it runs 250rpm, i look at the gauge, and i see the idle coming up very slow till 650rpm again.
Also had allready 3 times, when getting off the highway the engine dies, and needs restart. after that it can run fine again or not
With AC on it seems to be a lot better.
Thans again,
Thans again,
#88
Thans again,
Thans again,
As far as I have talked to 95 Celsior owners, many of them started to have the problem after aged. Some 10 years / 100,000km and others some more. They say cleaning the throttle body and cleaning the injectors may fix the problem but I know many not fully successful.
Changing the ECU from 89661-50240 or 89661-50241to 89661-50380 can fix it most of the case. The 89661-50380 has a newer engine management system that prevents the engine goes to too low rpm in certain severe conditions as far as I was informed.
Regarding the availability, I sometimes have seen the 89661-50380 was sold at the Yahoo Auction in Japan below.
http://auctions.search.yahoo.co.jp/s...ab_ex=commerce
Currently, the 89661-50380 is not sold but you'd better to watch. The problem is that many sellers do not ship abroad except some.
There is a person who has succeeded to fix the problem buying and using it with an additional work. His original intention was to fix different problems as were explained by LScowboyLS at #1 post here. Changing to the 89661-50380 and replacing all the Nichicon PF(M) capacitors prior to install it fixed everything and he was very happy.
#89
Now we are talking! Thanks guys for the info and video. Its exactly what my car also does.
Buy i see that you live in Japan, can you not could get easy parts for a reasonable price?
Funny! He has the same alarm as i have in my car!!
#90
There are some agents who bid instead of someone who lives in abroad. Below are those agents.
http://en.kaigai-tenso.com/
http://frontier-e.com/en/index.htm
https://www.japantodoor.com/help.asp?idno=49
http://www.tenso.com/en/
I have never used them and I have no idea to comment which agent is good neither.
Sorry for the limited suggestion but this is the most I can do for you.
