All my crazy Lexus issues SOLVED!! (ECU-leaking capacitor)
#1111
Hi Yamae-San, LScowboyLS,
I searched in Digi-Key website and came up with:
For 3.3 uF, 50v capacitor, below is the link. Can i used anyone of these?
http://www.digikey.com/product-detai...0314-ND/266323
http://www.digikey.com/product-detai...9-1-ND/4319996
http://www.digikey.com/product-detai...1888-ND/589629
As for 1.0 uF, 50v - no polarity
Please help which one shall i used.
My capacitor detail is:
1.0 uF 50v KME BP 78S(3) (M) 105 deg C
Thank you.
Thank you.
As for 1.0 uF, 50v - no polarity, you don't need to replace it since it's a KME and it doesn't contain the liquid QAS. It's a capacitor used for a coupling purpose not for a ripple rejection and it lasts many many years.
#1112
For 3.3 uF, 50v capacitor, I recommend you to use this.
I will feed back the results in due course.
Kind Regards.
#1113
What-a-super-helpfull-post!..
not experiencing any of these; but a very interesting read none the less! I'll remember about this. +loved seein MacGyver in there! ..I can dig it. ;]
Brooke LS400BL80
Brooke LS400BL80
#1114
Hi!
My Ls400 is a 1993 model for European market.
ECU #89661-50160
I opened it because I just purchased the car that has been sitting for a long time, and I'm repairing it.
Inside the ECU, i found the 8 caps already listed for the 1993-1994 model, but someone already changed them for TEAPO capacitors (they put 10μF + 4.7μF to get 15μF).
So I will recap it again
I want to thank Yamae and LScowboyLS for the information and the recommended replacement caps, but since the old ones were Nichicon PF series, why not just stick with the manufacturer direct replacement which is the PJ series?
The ESR is very similar to the originals and the ripple current is slightly better.
The KZE ESR value is 1/4 the original one, can't this detune the LRC combo and make the power circuit instable?
Regards.
ECU #89661-50160
Regards.
#1115
Hi!
ECU #89661-50160
Regards.
ECU #89661-50160
Regards.
The availability of Nichicon PJ series is extremely low and I needed to find some others available. If you are able to purchase the PJ series, why don't you try those?
As I have checked different capacitors picking up in the market, some of latest low ESR capacitors were OK to use. The stability of the error amplifier relies on the phase rotation and the remaining gain of it. As far as I have tested listed capacitors, those had margins to begin to loose the stability. Some ceramic capacitors were still OK but quite marginal, I found.
Speaking of TEAPO, a Taiwanese company which used TEAPO capacitors many for their products had problems in the North American market due to the capacitor's quality issue and finally the company was bankrupted, I remember. As LScowboy knows and suggests, it is wise to select and use Japanese major brand capacitors purchasing from reliable sources.
#1116
I have the worst luck acquiring ESR Data from these companies. I have sent multiple emails over the course of months and have not gotten information back from them.
If they were ever to even get back to me how do I know that the ESR percentages are what my ECU requires? Should they share "all 9 capacitors" the same numbers in ESR?
#1117
I have an aristo 2jzgte, And my ecu had the following caps inside "almost all of which were bad"
3x H9141 47UF 63V
2x H9149 10UF 50V
2x H9134 100UF 10V
1x H9143 220UF 16V
1x H9149 15UF 35V
I have found all of these on digikey said website and they had written back to me that I should contact the manufacturers individually to Aguirre ESR Data and that they did not have it available. I emailed the companies directly and they don't get back to me.
At this point I'm really frustrated because I really want to repair this ECU.
3x H9141 47UF 63V
2x H9149 10UF 50V
2x H9134 100UF 10V
1x H9143 220UF 16V
1x H9149 15UF 35V
#1118
For an example, Rubycon ZLH can be found at below. This is just a result of the Google search using key words "Rubycon" and "ZLH".
http://www.rubycon.co.jp/en/catalog/...inum/e_zlh.pdf
Some manufactures specify the impedance instead of the ESR but it is quite easy to assume how the capacitor is capable to reduce the ripple with that figure.
#1120
Thank you so much to the OP of this thread. I recently purchased a 00 LS400 and as soon as I got home it had the hard starting and intermittent tachometer issue. I'm an electronic technician by trade. When I noticed the issue with the car I was hoping it wouldn't be an ECM issue, but it was clear it was a dirty/corroded connection problem. I've ordered the caps for my own car and will have one of my friends at work whom SMT solders all day long do the work for me as I haven't soldered in a decade or so.
#1121
Finally completed Caps Change on a 97 LS 400. Only 6 on this model but the difference was not suttle
transmission shifts smoother ! Still too early to know all the issues are corrected.
Time will tell.
getting ready
pre clean connector points
make sure soldered joints polarity is observed
Only 1 leaking cap
Time will tell.
getting ready
Only 1 leaking cap
#1122
*photo courtesy of distinguished Japanese ECU engineer Yamae
IMPORTANT: The capacitors may look perfectly fine and yet be bad, they look great at first, then deteriorate and cause damage to the ECU very quickly
MODELS/ENGINES AFFECTED:
This issue affects all Lexus & Toyota models with the following engines: 1JZ, 2JZ, 1KZ, 1UZ, 5E, 1G, 3S
The following are some of the models affected:
● Lexus LS400 - 1990-2000 (in 1997 and earlier models, the problem is extremely common)
● Lexus SC300 - 1993-2000
● Lexus SC400 - 1992-2000
● Lexus GS300 - 1993-1996
● Toyota Celica GT - 1985 -1998
● Toyota Supra Mark III (JDM) - 1986-1993
● Toyota Supra GT - 1995-1997
● Toyota Supra Mark IV - 1993-2002
● Toyota Supra Twin Turbo - 1993-2002
● Toyota MR2 - 1990-1999
● Toyota Camry - 1987-2001
● Toyota Soarer - 1992-2000
● Toyota Aristo - 1993-1996
● Toyota Celsior - 1990-2000
SYMPTOMS:
Please understand that any one of these symptoms can be a sign of ECU capacitors beginning to fail. - You do not need all or most of them to have this issue!
Your ECU capacitors are strongly suspected if you have at least one of the following intermittent issues on your Lexus or Toyota:
● problems in getting into diagnostic mode or scanner says "no communication"
● random dropping into "limp home" mode
● weird shifting problems
● OBD port is unresponsive, seems dead
● throwing random fault codes
● engine won't rev out/rev limits at 2000 or less rpm
● engine runs like crap, then suddenly runs fine again
● random not starting or cutting out
● low idle or erratic idle
● often very hard to start, requires starting fluid
● transmission will not automatically shift, only manual shift is possible
● transmission jerks from 1st to 2nd gear, and kinda slips from 2nd to 3rd
● no A/C compressor operation
● idle speed rolling up and down, or sometimes too low and sometimes too high
● speedometer not working reliably
● speed (cruise) control not working
● tachometer not working sometimes
● air bag light flickering intermittently
● A/C going into reset with flashing front defog light (front defog light typically flashing 10 times)
● check engine light on sometimes, but no codes stored, often in concert with ECT light
● ECU not communicating with scanners or not displaying codes with jumper installed
● bad sulfur exhaust smell in concert with not running right above
I was actually experiencing several of these symptoms including ECU not wanting to communicate!
So, with no engine diagnostic codes to work with, I checked all of the grounds, voltages and other obvious causes, and then in a MacGyver-Steve Jobs moment of insight, I decided it must be the electrolytic capacitors inside the ECU, which had appeared fine in an earlier inspection a few months earlier when the problems began. I suspected it was the capacitors because I discovered this problem back in the 1990's on Nissan 300ZX and the Mitsubishi DSM models. History just keeps repeating itself! - It was also bound to be ECU-related, because this diverse set of issues has only on thing in common - the ECU!
sure enough, upon re-inspection, the corrosive leakage was very bad, so bad that the main circuit board could barely be saved!, I replaced all 6 electrolytic capacitors, and now every single problem listed above is gone! - and the engine also seems to have more low end power than it had even before the symptoms above appeared!
if you recognize ANY of these symptoms listed above, bad ECU capacitors are a likely culprit!
I now believe any Lexus over 12 years old would greatly benefit from having ALL 6, 8, or 10 electrolytic capacitors in the ECU replaced with high quality new ones! - these were not part of a defective batch, but rather a quaternary ammonium salt capacitor issue, as explained by world-renowned ECU engineer Yamae in post #8 below. (we are very lucky to have him here at Club Lexus!)
this is NOT something a junkyard computer would solve, it is an age and sitting up problem, a junkyard ECU would have the same issues.
IMPORTANT: It is critical that you use the exact premium Japanese low ESR capacitors I have linked to below in the recommended capacitors section, even if you are having someone else do the work, the correct capacitors are very rare type and they will not have them locally - if they use other capacitors, the repair will not solve the problems you are having!
the power difference alone makes it worth doing, and just because an electrolytic capacitor looks good, doesn't mean it is - 93-97 LS models are showing up with this capacitor issue in particularly high numbers and other models such as SC model are showing up in high number on even earlier years such as 1992, this also affects the 2JZ and other Toyota engines!
LET'S FIX IT!!
a new ECU would also solve the problem, those cost $2400 at the dealership, the parts I used to make mine just like a new one are less than $20 delivered from Digi-Key - and it is important to order from an authorized dealer of these great capacitor brands in order to avoid counterfeits - so FORGET EBAY, AMAZON, ETC.
make sure you use 105C rated low ESR caps from the 4 reputable Japanese capacitor companies Rubycon, Nippon Chemi-con, Panasonic & Nichicon
it is CRITICAL that the replacement caps be low ESR type and from one of the brands listed above - don't cheap out on your vital ECU!
WARNING - DANGER: this is not a good first-time soldering project, the existing capacitor removal and associated desoldering, cleaning, inspection, soldering and re-inspection is involved and is in some very tight places, you must be experienced at soldering and pretty good at it, or else you need to locate someone who is very experienced at soldering, and then you should buy the special capacitors this job requires, and then let him or her do the operation of replacing them - the NipponDenso ECU in your LS400 is a delicate piece of very expensive electronics. If you wouldn't feel comfortable taking apart a laptop computer and getting it back together successfully, then you probably do not want to be doing the electronic portion of this repair.
If you need further advice on recapping, you can post here in this thread!
which caps you need and how many depends on the year model of your LS400
I would advise you pull the ECU and verify the cap values before ordering, to make sure. You can reinstall the ECU in 5 minutes (leave the lower glove compartment out for now) and you can drive the car until the caps arrive in the mail from DigiKey (normally just a couple of days)
WARNING: You must use premium Japanese low-ESR capacitors for this repair to be successful, this kind of capacitor is very rare, they do not stock it locally, you must order it from the links below!
1990-92 LS400 needs 10 or 11 caps as follows:
Qty. 3 of 10μF - 50v
Qty. 2 of 15μF - 35v
Qty. 3 of 47μF - 63v
Qty. 2 of 100μF - 10v
Qty. 1 of 220μF - 16v
1993-94 LS400 needs 8 caps as follows:
Qty. 2 of 10μF - 50v
Qty. 1 of 47μF - 63v
1995-97 LS400 needs 6 caps as follows:
Qty. 2 of 10uF - 50v
Qty. 1 of 47uF - 63v
Qty. 2 of 100uF - 10v
Qty. 1 of 220uF - 16v
1998-2000 LS400 needs 11 caps as follows:
Qty. 2 of 10μF - 50V
Qty. 3 of 47μF - 63V
Qty. 2 of 100μF - 10V
Qty. 1 of 220μF - 16V
Qty. 1 of 33μF - 35V
Qty. 1 of 47μF - 25V (special BP capacitor) - high reliability capacitor, replacement recommended but not critical
Qty. 1 of 330μF - 35V - high reliability capacitor, replacement recommended but not critical
1998 and up owners: you can replace the capacitors of your original ECU without affecting security and the theft deterrent system, but keep in mind that if you get another ECU say from ebay or a junkyard, it will have to be reprogrammed by the dealership or a better locksmith before your car will start with any ECU that is not the original one that came with your car!
WARNING: You must use premium Japanese low-ESR, high temperature, long life, high ripple rejection capacitors for this repair to be successful, this kind of capacitor is very rare, they do not stock it locally, you must order it from the links below!
~~~ CURRENTLY RECOMMENDED CAPACITORS: ~~~
DANGER! - Will Robinson - COUNTERFEIT capacitors are a SERIOUS EPIDEMIC - make damn sure your capacitors come from the factory authorized sources below, those capacitors you found a deal on, on ebay or elsewhere online are very likely FAKES! - most premium Japanese capacitors in the United States are shipped from three principle distributors: Digi-Key, Mouser, and Newark Electronics. Anywhere else is likely a questionable source!
(this list is dynamic and will be updated as Yamae & I find additional good candidates and rule out others)
(recommendations are based on USA availability - the best capacitor made does us no good if it is not readily available)
the voltages specified in the recommended caps below are sometimes higher than the originals, this is a good thing!
the one to get in 10uF is the 50V Chemi-con KZE EKZE500ELL100ME07D - if sold out, use alternate factory authorized source here: EKZE500ELL100ME07D
in the 15uF - the 63V Chemi-con KZE EKZE630ELL150ME11D
also fine is the 100V Nichicon PW UPW2A150MPD
in the 33uF - the 35V Panasonic FR EEU-FR1V330
also very good is the 100V Rubycon ZLJ 100ZLJ33M8X11.5
in the 47uF - the favorite is the 100V Chemi-con KZE EKZE101ELL470MJC5S (sometimes sold out)
also very good is the 100V Panasonic FC EEU-FC2A470
also very good is the 63V Panasonic FR EEU-FR1J470B
in the 47uF special BP - the 35V Nichicon EP UEP1V470MPD
also fine is the 50V Nichicon EP UEP1H470MPD
in the 100uF - the 35V Rubycon ZLH 35ZLH100MEFC6.3X11
also very good is the 50V Panasonic FR EEU-FR1H101
also very good is the 50V Chemi-Con KZM EKZM500ELL101MHB5D
in the 220uF - very impressive is the 50V Panasonic FR EEU-FR1H221
also very good is the 50V Chemi-con KZE EKZE500ELL221MJ16S
also very good is the 50V Panasonic FM EEU-FM1H221
and the new 50V Nichicon HW is my new favorite! UHW1H221MPD
in 330uF - I recommend the 35V Rubycon ZLH 35ZLH330MEFC10X12.5
or alternatively the 35V Panasonic FC EEU-FC1V331
~~~>>> special thanks to world class ECU engineer Yamae from Japan <<<~~~
who got me thinking about how ECU's operate in my head, which lead to this breakthrough! (and also thanks to TV character MacGyver, it's what he would have done!)
no one understands Toyota ECU operation and design on Club Lexus anywhere in the same league with our special Japanese guest Yamae!
just consider him a guest expert ECU engineer from Nippon Denso, and you wouldn't be far off.
ECU removal:
always disconnect the negative battery cable before disconnecting or reconnecting an ECU
beware: there is at least one hidden bolt inside the lower glove box behind a secret panel (not joking about this) the diagram below will help, but it can be a little tricky to get the lower glove box out the first time, just keep at it, and you eventually will locate all of the fasteners
I take NO responsibility for any damage you do to your ECU from any information you obtained from this post. DO THIS AT YOUR OWN RISK!!! If you completely hose your ECU, don't come whining to the cowboy! Nor do I want it sent to me for repair! Untangling someone's 'handiwork' is more frustrating than battling the original problem! If you have any doubts about your skills, DON'T TRY THIS!! - If you do screw it up, it is not the end of the world, just purchase the same part number ECU on ebay from a high rated (99.5%+) seller for around $125 or so and find someone to do this cap replacement job who has experience.
Also - NEVER use 'cold heat' types of soldering irons!! They work off the principle of an ARC welder, and emit a current. This can instantly destroy your ECU board when contact is made. If a good soldering station is not available to you, a 40 watt solder pencil with a standard tip on it will work fine.
STEP-BY STEP REPAIR GUIDE
if you have patience and soldering skill, it's not too difficult!
here is what I did:
CAUTION: BE VERY GENTLE with flexing the 2 or 4 gray ribbon cables that connect the 2 mainboards - they will not tolerate rough handling! - they will take a normal amount of flex required to open up these boards flat for working on them, so you don't have to be a complete scaredy-cat!
parts/tools to round up:
the ECU carefully opened up (be gentle with the ribbon cables)
the new capacitors (you did procure the ones Yamae & I specified above, right?)
rosin core solder 63/37 (Radio Shack p/n 64-015 or equivalent)
rosin solder flux (Radio Shack p/n 64-022 or CAIG DeoxIT rosin flux p/n RSF-R80-2)
40+W soldering iron or soldering station, 75W max - no soldering guns! (Radio Shack p/n 64-2071 or equivalent)
● my favorite soldering station: Hakko FX-888D
● my next favorite: Weller WES51
solder sucker (Radio Shack p/n 64-2060 or equivalent) another type that is also good is Radio Shack p/n 64-210 (some people find this a huge help, I don't use them but very rarely)
stainless steel safety pin or, if available, a stainless steel dentist's pick is also fine of the tip is straight and sharp like a needle
nail clippers or flush cutters (Xuron 9200 or similar)
91%+ isopropyl alcohol
baking soda
vinegar
distilled water
CAUTION: - static electricity can kill an ECU - some people wear anti-static wrist straps, but I find them a pain, here is a better plan and what I do in my electronic's bench: all 100% cotton clothing and bare feet!
FIRST: - take photos of what caps go where originally, plus make a DIAGRAM of cap sizes & placement!
1. - remove old caps using soldering iron heat or desoldering iron and a simultaneous back and forth tug after making diagram of values and placement, just keep tugging, they will come out
2. - gently brush areas of board where caps were using toothbrush with baking soda/water paste to remove any acid leakage residue
3. - wash area with vinegar to remove any caustic base damage
4 - inspect board copper traces to insure that they are still intact, it is OK if they are now a brighter copper color than surrounding traces, but severed or completely eaten away traces will require professional repairs and you are probably better off getting another ECU from a junkyard or ebay and replacing the caps in that one
5. - rinse board with distilled water to remove vinegar acetic acid
6. - rinse board twice with 91% isopropyl alcohol
7. - inspect desoldering job with loupe
8. - using medium large safety pin, re-make holes in desoldered pads in board to accommodate easy installation of leads of the new caps, heat up the solder pad, insert safety pin, let cool and the stainless safety pin will twist right out, leaving a perfect hole for new cap leads!
9. - solder in new caps, double checking polarity (+/- orientation) - use 63/37 rosin core solder, and get some rosin solder flux (I like Radio Shack p/n 64-022) and cover the solder area well - slather it all over where the new caps will be soldered - the new capacitors do not like extended heat, just get in and get out with the soldering iron, and make sure iron is ample wattage (like 40W+) - I do not like to apply heat for over 3-4 seconds at one time. Use LIBERAL amounts of the RS/CAIG rosin flux mentioned above in the parts list, this is the key to making the soldering process behave!
10. - trim leads on reverse side of board of each installed cap with clipper
11. - rewash board with 91% or higher isopropyl alcohol
12. - inspect soldering job with loupe
13. - blow compressed air to make sure no clipped leads or stray solder remain on board, use about 25 PSI or less, it's a circuit board, not a crankshaft!
14. - Once ECU is reinstalled into car and everything is reconnected, only then do you want to reconnect the negative battery terminal
15. - BEFORE cranking engine the first time, click the ignition switch over to the RUN position for 1 minute to let the other ECU components acquaint themselves with the new caps and let them precharge.
updates 10-24-2014
For the '1991 there is a 9 capacitor variant ECU. See post #966
https://www.clublexus.com/forums/ls4...ml#post8721523
1991 there is a 10 capacitor version. See post #975
https://www.clublexus.com/forums/ls4...ml#post8736858
Thanks to Yamae for researching the part#'s for the North American ECU's.
#1123
royjackson,
for 1998-2000 just replacing the computer is ok , it would start the engine, but a number of simple additional operations is required to do everything properly
for 1996-1997 (non vvti) you will need to sync engine computer to immobilizer computer.
#1124
I did some research and wanted to bounce these by you. I want to be able to contribute to the Aristo 2jzgte ecu owners experiencing the same issues.
These have been what I could find because of your thread:
47UF, 63V (493-1934-ND) PW Series Nichicon
http://www.digikey.com/product-searc...nd&WT.z_header
10UF, 50V (565-1702-ND) KZE Series United Chemi-con
http://www.digikey.com/product-searc...n&site=us&Ntt=
100UF, 10V (565-1641-ND) KZE Series United Chemi-con
http://www.digikey.com/product-searc...ader=search_go
220UF, 16V (P14393-ND) FR Series Panasonic
15UF, 35V (P15812CT-ND) GA Series Panasonic
#1125
None of your link works by my computers, DETONATION. I have tried to access using 2 different computers, a Linux one and a Windows7 one. Were you sure you linked properly?
As long as I search the Net, Panasonic capacitors can be found at below.
http://industrial.panasonic.com/lecs...A0000PE370.pdf
Why don't you search the Net all by yourself if you want to contribute Aristo 2jzgte owners?
Those who expect others to do and don't act themselves can't help others, I must say.
