Transmission gear jerk
As the title says, I notice on my 98 ls400 the transmission seem to jerk a little when shifting to 3rd gear, all the other gear shift fine and very smooth. It happen before I did a transmission drain and fill. Even after the drain and refill it still does the same. Have anyone experience this? Is it normal if not is there something I can try it possibly fix?
make sure you use real Toyota T-IV fluid and the Aisin transmissions seem to be a bit sensitive to being underfilled or overfilled by even a little bit, so recheck the level, both cold and hot while running in Park and adjust if necessary - that's about all you can do that is cheap.
About where does the level should b at? I did out two quarts of type IV in already
The dipstick does have a textured range, just get it really good and hot after a drive on the freeway then check it on very level ground, it should be right at the top line of the textured range.
christcorp
ES - 5th Gen (2007-2012)
26
03-05-24 04:28 AM
lserlohn
RX - 1st Gen (1999-2003)
41
06-06-16 05:45 PM
bowen.chau
06-02-13 07:58 PM
