UCA Slaps = Airbags pop
Old 09-29-12, 10:25 AM
dengman
dengman's Avatar
Well, good news for me. I took the seatbelts apart and removed the pretensioners to unlock the seat belts. The seat belts work mechanically now. It does not reel in as good as since I had to take off the coil spring to get to the pretensioners. I have to give it the extra pull and reel in if i want to get it all the way back in after the initial unbuckle reel in.
I can atleast drive the car again till I find airbags, seatbelts. Which will be hard to come by.
Old 09-29-12, 02:44 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
sounds safe...
try car-part.com to search for parts near you
Old 09-29-12, 04:19 PM
dengman
dengman's Avatar
Originally Posted by PureDrifter
sounds safe...
I've been on car-part every morning for a while. I've been trying to located a trunk lid too since mine is tweaked a little..
Old 09-29-12, 04:46 PM
lonnie247
lonnie247's Avatar
Saw these on eBay the other day.
http://www.ebay.com/itm/99-00-1999-2...745709&vxp=mtr
http://www.ebay.com/itm/99-00-1999-2...745d08&vxp=mtr
Old 09-29-12, 08:57 PM
Kaiyin
Kaiyin's Avatar
damn, glad you're okay. This has me worried since I ride a little bit lower and my UCAs bang a lot (yeah, I've been lazy and haven't cut my towers yet). I've hit some pretty hard bumps too. Luckily haven't had this happen. Hopefully it never does.
Old 09-30-12, 12:58 AM
dengman
dengman's Avatar
My UCAs are touching the towers just sitting still.
Maybe you could pull the SRS fuse till you modify the towers?
Old 09-30-12, 02:30 AM
whit3b0y
whit3b0y's Avatar
sounds odd, about 3wks ago i was driving 99 LS4OO through construction zone, where they had ground down the road. was going 45ish... any way hit a man hole that was still at original hieght. BANGING Towers! traction,vsc,check engine all started flashing. I took a side road and the motor started to grind. It took a few moments to get it into N, then coasted to an oil can Henry's. smashed steel oil pan through the sump and bent crank also cracked the aluminum half open. Cracked steering rack support and tranny wide open. Bags still in perfect shape, no deployment.
You were going more than twice as fast, with less damage and bags deployed.
Spartanlol
10-09-18 01:47 PM
chargerfan
SC400 / 300 Classifieds
16
02-11-13 05:41 PM
Stage3
07-11-06 09:07 PM
jvillagran
09-18-05 10:47 PM
P.Williams
Suspension and Brakes
06-23-04 03:34 PM
Quick Reply: UCA Slaps = Airbags pop
