2-piece Front Rotors
the vendor that handled the aftermarket solution is R1concepts (CL vendor).
https://www.clublexus.com/forums/cl-...rake-pads.html
you may be able to work with them on a solution for the LS.
though keep in mind the demand for a two piece solution is much less for the LS than others, so they may be less inclined to help.
they may charge a ton for the R&D for a one-off product for you!
Disc brake australia ("dba") two-piece rotors
Posted earlier on two-piece rotors as a way to reduce unsprung weight by up to 8 pounds.
Visited with Mathew Roskey, USA Sales Manager at DBA regarding continuing availability of front two-piece rotors for our LS400.
DBA will produce two-piece LS400 front rotors in 50 piece production runs.
https://www.dba.com.au/products/prod...ors/hd-5000xs/
Matt advises actual weight savings approximately 3 - 5 pounds over stock rotors
DBA offers single piece rotors with various options
https://www.dba.com.au/products/prod...tors/hd4000xs/
One and two piece rotors incorporate the same metallurgy:
https://www.dba.com.au/tech-zone/pro...nology/xg-150/
and heat-treating:
https://www.dba.com.au/tech-zone/pro...hnology/tsp-4/
They claim a more efficient "Kangaroo Paw" cooling vane ventiation configuration.
https://www.dba.com.au/tech-zone/pro...w-ventilation/
Anyone interested in measuring peak rotor temperatures, DBA uses thermographic paints to allow user to determine peak temperature thresholds:
https://www.dba.com.au/tech-zone/pro...aint-markings/
If questions, feel free to contact Matt.
and heat-treating:
