What did you do to your LS400 today?
Old 04-03-15, 04:52 PM
  #271
Panda90
Panda90's Avatar
Put in my double din and realize the USB i use to plug in my iPod doesn't let the radio read the iPod like it should.
Old 04-03-15, 07:05 PM
  #272
JJDAG
JJDAG's Avatar
I went for a drive for no reason then filled my gas tank with 93
Old 04-04-15, 09:10 AM
  #273
sha4000
sha4000's Avatar
New radiator, fan clutch and DIY tranny flush.
Old 04-05-15, 07:15 PM
  #274
pmarr
pmarr's Avatar
well not me but my daughter did, on her way home from Santa Cruz today, drove for about an hour and a half, on the freeway, in second gear in her 91 LS400. Total knucklehead. Used a half a tank of gas for that hundred mile stretch. First road trip away from home. Guess I should have told her about the tachometer. Thing is so smooth couldn't tell the transmission had not shifted into gear. Said, "I was wondering why the engine was louder today". Good grief.
Old 04-06-15, 05:57 AM
  #275
Legender
Legender's Avatar
Ouch... feel your pain, pmarr... fortunately my daughter was very into cars and very attentive... after a timing belt job on her little honda, she noticed the oil light came on... Immediatly pulled over and called me. Seal had failed and oil poured out of it. Tow, replace the seal, fresh oil and she was up and running with no major damage. Way proud of her.
Wash, polish and was on one today. Other one will be next weekend.
Old 04-06-15, 06:47 AM
  #276
OMAHA
OMAHA's Avatar
Default Pirellis
Originally Posted by Legender
Thanks for the info... I will look into the Pirellis for sure. Only bought the Michelin's before, but as I've got the car in the shop getting new timing belt, valve cover gaskets, strut rod bushings, engine mounts and alignment, was looking to cut some costs somewhere.
I got four new Pirellis P7s @ DISCOUNT TIRE for $540 with taxes and everything included. They do great in snow, better than the Michelins, and with the new brakes and rotors, my '94 LS runs SMOOTH!
Old 04-06-15, 09:52 AM
  #277
LsG86
LsG86's Avatar
That's a great deal! Now I wish I did get the Pirelli P7s. By the way, do you supposed to get a four wheel alignment after you install new tires?
Old 04-06-15, 07:02 PM
  #278
OMAHA
OMAHA's Avatar
Default fresh rubber
Yes, the alignment was free....I also got the "V" rated P7s...I called around and got quotes.....they basically price matched.
Old 04-08-15, 06:21 PM
  #279
AnitaBjay
AnitaBjay's Avatar
Just traded for my first ls today. Got myself a 94 with 128k, runs like a top. Going to be big weekend since im going to be doing a tuneup and timing belt to know it will last until i change it again
Old 04-08-15, 07:37 PM
  #280
paulo57509
paulo57509's Avatar
Oil Change
Out: Pennzoil Platinum 5w-30, Bosch Distance Plus filter
In: Pennzoil Platinum 5w-30, Denso filter
Trans Drain/Refill
Out: Factory fill is my guess. Car only has 70k miles. Yeah, a bit overdue.
In: 3 qts. Toyota T-IV
Old 04-08-15, 09:33 PM
  #281
b17what
b17what's Avatar
Originally Posted by paulo57509
Oil Change
Trans Drain/Refill
question for you. Any car I have ever tried to do a trans fluid change on ended up for the worse. Is there anything I should worry about if I do this? My car has 94k on it and probably has never been done. It shifts perfect right now though.
Old 04-08-15, 10:44 PM
  #282
b17what
b17what's Avatar
Got bored of the stock exhaust and put on new mufflers. Still a little quite for my liking. Probably will remove resonators next. Have to fix an exhaust leak up front too...
and that is my poor supra in the background waiting for it's new motor.
Old 04-09-15, 09:10 PM
  #283
paulo57509
paulo57509's Avatar
I'm going to assume you've done drain/refills on automatics and they soon blew up afterwards? I don't worry about this. I feel if it happens it's only a bad coincidence, even though it happened to me recently on a GM transmission that has known issues with the 3-4 clutches. There's no way to prove that the transmission would have lived if the fluid were never changed. You can't go back in time.
I wouldn't worry about it provided you're not abusing the transmission (it's not a manual) and you use the specified fluid. However, YMMV.
BTW, my car just turned 70k. That GM transmission had 130k miles on it and also had regular fluid changes so I'm still not convinced that fluid changes cause issues.
Old 04-10-15, 05:29 AM
  #284
Legender
Legender's Avatar
I think it's coincidence that it blew when it did. I put 3 trannies in my 80s model Bonneville and was headed into my
4th at only 120k miles when I said goodbye to US cars and went with Toyota... never looked back.
Old 04-10-15, 10:39 AM
  #285
RA40
Super Moderator
RA40's Avatar
The Toyota tech I talked to relayed that trannies that don't get a fluid change tend to go south at the 150-200K mark. Driving style also depends, in city or highway. The samples we have here when serviced do well over the 200K range. The majority of LS400 owners aren't looking for super long term cars so when this part fails, the car is usually a parts donor if there is anything good. For those that want a long term car, it would be advisable to do the fluid changes as recommended.
I posted this in the car chat a bit back about an Audi that didn't get an oil change:
http://jalopnik.com/what-happens-if-...-fo-1692660828
Basically fluids have a determined usefulness.
Quick Reply: What did you do to your LS400 today?
