What did you do to your LS400 today?
Old 04-10-15, 04:07 PM
  #286
sha4000
sha4000's Avatar
Originally Posted by galelee510
The speedometer on my ls400 would sometimes not work, then would work, etc. Now it has stopped working. Any suggestions?
Wrong thread. Try this one. It would have popped up first if you used the search on the right side.
Old 04-10-15, 06:02 PM
  #287
Legender
Legender's Avatar
Originally Posted by OMAHA
I got four new Pirellis P7s @ DISCOUNT TIRE for $540 with taxes and everything included. They do great in snow, better than the Michelins, and with the new brakes and rotors, my '94 LS runs SMOOTH!
Had stopped by SAMs and saw they had an immediate $80 discount on the Pirelli p7 h rated. Picked up the set of 4 for only $475. Pretty happy with that price and hope I'm as happy with the ride. They had to order them so should be here next week. I think that rebate ends on the 12th if any one else is interested.
Old 04-10-15, 10:07 PM
  #288
lexmoose
lexmoose's Avatar
Just replaced the drive belt and did the airbox hack. That first pull put a big smile on my face, this stuff is better than pills.
Old 04-11-15, 10:59 PM
  #289
lexmoose
lexmoose's Avatar
Installed my 2din NAV headunit.
Old 04-13-15, 11:56 PM
  #290
westy96
westy96's Avatar
Started stripping my spare Celsior for a drift car build today.Sitting on blown airbags atm lol. I have 18kg coilovers for it tho bucket seats and some of the tubing for the rollcage (not nearly enough tho), manual box just no clutch. i also have a turbo for it but im going to get it done and sliding before turboing. just going to weld the rear diff.
most of the interior loaded for dump. lots of weight saved will know exactly how much after i dump it
Old 05-08-15, 10:19 AM
  #291
Finn
Finn's Avatar
It was time to change some fluids.
out/in Total Quartz 9000 Energy 0w-30 and Wix WL7172
out/in Mobil 3309
out/in Mobil Mobilube 1 SHC 75W-90
Old 05-15-15, 03:40 PM
  #292
mccrimmon
mccrimmon's Avatar
Broke out the Lexol, cleaned and conditioned the leather. So Fresh n So Clean!! Not bad for 15 years old.
Old 05-17-15, 05:17 PM
  #293
cgawelko
cgawelko's Avatar
Hit the leather with some VLR to keep it plump and amazin. Ran some new vacuum hose to my MAP sensor. Moved the pile of crap removed from the car from three corners of the garage to one giant pile.
Thinking about putting the hood back on but we will see.
Old 05-17-15, 06:18 PM
  #294
RA40
Super Moderator
RA40's Avatar
These days ours doesn't get much road time, might get driven a couple times a month. Today it went to the gas station and a grocery run. Was to lazy to get up and head over to the Westminster meet. Bad moderator to not support the forum.
Old 05-18-15, 05:54 AM
  #295
SonicC
SonicC's Avatar
I wanna play...
Replaced front pads Saturday and got front rotors resurfaced, then did a brake fluid flush, steering fluid flush...replaced rear end links.
Cleaned left side OCV:
Replaced right side ball joint and tie rod ends on both sides
Then put everything back together and dropped it off at the paint shop last night
Old 06-24-15, 02:23 PM
  #296
JJDAG
JJDAG's Avatar
I changed the oil again last week and today for the first time I let my wife drive my LS Of course I was in the passenger seat giving direction, she scares me...
Old 06-26-15, 11:12 AM
  #297
wnyjazz
wnyjazz's Avatar
Having an expert on these ECU's fix the one from our '94. 1 of the 5 leaking capacitors did some damage that is going to be tricky to fix as seen in this pic.
Old 06-26-15, 04:43 PM
  #298
akswagga
akswagga's Avatar
I was trying to clean the egr vavle but couldnt get it but i did clean the throttle plat holes ( the upper plate )
Old 06-29-15, 06:18 PM
  #299
JJDAG
JJDAG's Avatar
Saturday I replaced both front strut bars, today I sent it in for 4 new tires and an alignment . Made a huge difference in the ride and handling
Old 10-23-15, 09:21 AM
  #300
Hiroshi12
Hiroshi12's Avatar
New akebono pads and new rotors up front. Also painted my calipers with some high-temp. ceramic paint.
Quick Reply: What did you do to your LS400 today?
