Idler pulley for drive belt, saved some $$$$
Old 10-04-12, 08:24 AM
Lexinky
Lexinky's Avatar
Default Idler pulley for drive belt, saved some $$$$
The idler pulley for my serpentine drive belt was failing, and I priced new ones for $50 to $75 ! ! !
I found just the bearing......... a 6301 double sealed Nachi brand on ebay for $10.
I had to knock the old one out of my pulley and pressed the new one in with the old bearing and then a properly sized socket to finish the last bit my bench vise.
It took maybe 10-20 minutes of effort to install the new one.
It's like brand new.
Saved me some $$$$$$
Maybe this will save someone else some too.
Old 10-05-12, 11:27 AM
timmy0tool
timmy0tool's Avatar
good news! thanks for the heads up. now i just hope i remember this when the time comes. how did you know it was failing? play in the bearing? leaks?
Old 10-05-12, 12:50 PM
LScowboyLS
LScowboyLS's Avatar
you can do basically the same trick with your Idle Air Control Valve (IACV) and take the cost down to around $50 rather than $800+
BROKERIN
RX - 1st Gen (1999-2003)
19
09-24-12 12:50 PM
tlylesbey
Performance & Maintenance
06-26-12 02:37 PM
deanbrown
10-25-08 06:06 PM
avalon42
03-09-08 06:02 PM
chuckb
16
10-30-06 04:39 AM
Quick Reply: Idler pulley for drive belt, saved some $$$$
