item above thermostat leaking?
whats the thing in the middle with the size 12mm bolt on? above the thermostat. i have a leak there. ill post a picture tomorrow.
They may have a listing but you'll probably just need to ask for an "aluminum crush washer" and the size you need. If you have or have access to a second car, I'd recommend just removing the bolt and the washer and taking it in!
You can also just remove it, trace its size onto a piece of paper and the. Get them to match it up. The ID is the measurement you should be most concerned about. Being in the USA will probably mean you'll have to make a SAE size work unless the parts store carries a lot of metric stuff.
DO NOT do that in the parking lot at the parts store... Unless you want a big mess of scalding-hot coolant spraying everywhere! haha
