Exhaust Query
#31
BahHumBug
you should search, you'd find threads like these...
https://www.clublexus.com/forums/ls4...spiration.html
https://www.clublexus.com/forums/ls4...-mufflers.html
#32
yours won't sound like that. can't compare the sounds of something with a different firing pattern, pushrod vs. dohc, carb vs. efi, and over 100Cubic inches in displacement.
Have seen both those threads already thanks (my car is actually one them when a previous owner had it lol).
Still not completely convinced 2.25 is better than 2.5 yet.
#33
BahHumBug
Yea wasn't meaning for a second that it would sound the same! Only that the 58 has the cross over pipe. You didn't mention if you have experience with it or heard about it?
Displacement vs. pipe size is a pretty well sorted standard (to some degree) but you can do whatever you'd like. I've laid out the reasons.
#35
i've mentioned it twice already, instead of your "balance pipe", which is known as an H-pipe setup, I prefer an X-pipe for the reasons detailed in my previous posts.
But thanks for the info, starting to get a good idea of what I will do now.
Listen up hippy, one more car without them won't make a discernible difference & If I do end up removing them both ill plant two trees
jdmSRT
01-01-09 02:51 PM
