Broken spark plug boot in cylinders 3,6,&7
Old 10-23-12, 01:38 AM
Kanderson1
Kanderson1's Avatar
Default Broken spark plug boot in cylinders 3,6,&7
LSCowboy.....and Forum...grabbed a 12" pair of needle nose pliers to pull out the broken spark plug boots......fail!! The previous boots were made of plastic. Its now so brittle, that everytime I attempt to grab them, they break into pieces. My next solution is to use a long screwdriver and hammer to break the rest of the plastic boots up from around the spark plug. Then vacuum out each cylinder or blow the debris out with an air gun. Then remove the spark plugs.......suggestions?
Old 10-23-12, 10:31 AM
Shmee
Shmee's Avatar
i'd avoid using the hammer but a long screw driver or a pick/awl would work to break up the rest of the boot before vacuuming it all out!
just make sure you get it all out before you remove the plugs
blasting some compressed air down there with a keyboard cleaner(if you don't have a compressor while sucking with the vacuum would also work if you do not have a super powerful vac.
Just go slow and be methodical and try to avoid snapping off the end of the plug!
Old 10-23-12, 10:47 AM
timmy0tool
timmy0tool's Avatar
never knew they were made of plastic, thought they were rubber. what year LS? miles?
Old 10-23-12, 10:51 AM
Shmee
Shmee's Avatar
no, they probably WERE rubber. but if you heat cycle rubber enough combined with a little petroleum contamination you will basically get something like plastic in time....
Old 10-23-12, 02:03 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
you get brittle aged rubber, not technically plastic
Old 10-23-12, 02:06 PM
Shmee
Shmee's Avatar
should i have emphasized the "like" more in my last post, PD?
Old 10-23-12, 02:30 PM
Kanderson1
Kanderson1's Avatar
Its a 1995 w 200k.... Trying to bring it back to life
05RX330AWD
07-11-17 12:25 PM
cheerio3
RX - 1st Gen (1999-2003)
02-08-15 11:21 AM
Handsome
Performance & Maintenance
09-29-14 08:46 PM
R4a2m0o
07-01-14 06:29 AM
alexamparo
GS - 1st Gen (1993-1997)
10-08-02 05:48 AM
Quick Reply: Broken spark plug boot in cylinders 3,6,&7
