Rear strut access
Sorry to have to ask guys, i have seen it before but I cant find it now. I have been looking but I'm running about of time.
HOW DO i GET TO THE REAR STRUT MOUNTS. IE REMOVE THE BACK SEAT?
THANKS!
THANKS!
Find all the bolts for the rear seat back and remove them. They're under the headrest, behind the center armrest, near the seat belts and probably a few more.
The seat cushion simply pulls out.(it takes some force)
Then if you pry on the rear deck cover, you can access and remove the bolts without the aweful task of removing the rear deck cover..
Are u trying to take out the whole back seat? Cause you do have to remove it to access the rear struts. Take out all the headrest lift the tab with Velcro and you should see bolts. One on each left and right side of headrest and 4 in the middle. After doing so pull the bottom seat up and that will give you access to the bolts on the bottom holding the rear back seats. Once done with that it should come out easily
