92 LS400 Stalls and Staves for Gas HELP PLEASE!!!!
Old 11-07-12, 10:35 AM
SSAstro
SSAstro's Avatar
Default 92 LS400 Stalls and Staves for Gas HELP PLEASE!!!!
after driving for 40 mies or so the car stalls and starves for gas. I have replaced Throttle Position Sensor, Fuel Pump Sensor, and Mass Air Flow Sensor. Any suggestions???
Old 11-07-12, 12:24 PM
steve2006
steve2006's Avatar
Have you read the fault codes? Have you measured the fuel rail pressure?
Could be a faulty fuel pump but there are many other causes.
Old 11-07-12, 09:59 PM
IncgntoLex
IncgntoLex's Avatar
I had a similar issue with my 91 ls. Car would run fine for a while then cut out and stall. It would then be difficult to start up. Everything I tested would always pass. I eventually determined it was a bad pump. The pump like any electric motor can fall victim to heat. Anytime I tested the fuel system was in my garage after the car was cooled down. When driving the vehicle the pump begins working and slowly heats up leading to failure during use. Once cooled down it may begin to work again. I hope this helps and good luck on the diag.
02msmg3
11-01-17 08:02 AM
1on1
18
05-15-17 03:07 PM
Lexcalibre
Performance & Maintenance
03-07-16 05:34 PM
Quick Reply: 92 LS400 Stalls and Staves for Gas HELP PLEASE!!!!
