Having a weird vibration issue. Any ideas?
Old 11-08-12, 07:17 PM
shorestyle
shorestyle's Avatar
Default Having a weird vibration issue. Any ideas?
So I bought a 92 LS400. Everything seems great except it's having a strange issue.
The car has a vibration/shaking. almost the same feeling of having warped rotors, when it's bad it feels like there is a flat spot on one of the front wheels. Only happens under these conditions:
-Decelerating or at light throttle/cruising. NOT when accelerating
-Only when the car is warm (starts to happen around 10 minutes after driving it)
-Happens very randomly. Sometimes badly, sometimes not so badly.
-Only happens when driving over 60 km/h (around 45 mph)
There's no shaking or play in the steering wheel. It just feels like the front end of the car is shaking.
At first I thought it just needed a wheel balance, so I went and got all 4 wheels balanced. Didn't solve the issue. The car also has the TRAC off light on all the time. I read that it means there's a DTC present. I ran it for codes and got a code 28. So I am going to be replacing the O2 sensors tonight. I have a feeling that won't change anything though, besides my fuel mileage. I also checked for tie rod play and there is nothing.
Anyone have any ideas? I'm pretty stumped.
Old 11-08-12, 07:59 PM
dengman
dengman's Avatar
strut rod bushing.
Old 11-08-12, 09:50 PM
shorestyle
shorestyle's Avatar
Originally Posted by dengman
strut rod bushing.
Positive about this? (given the symptoms)
Thanks for the response
Old 11-09-12, 05:31 AM
johnnyg66
johnnyg66's Avatar
Engine mounts. helped me.
Old 11-09-12, 08:52 AM
shorestyle
shorestyle's Avatar
Sorry, I forgot to mention...
I highly doubt it's an engine issue. When the problem starts to happen, putting the car in neutral doesn't change a thing. And the engine runs fine when idling/accelerating.
Old 11-09-12, 11:05 AM
RA40
Super Moderator
RA40's Avatar
With a 92, you'll have the potential for a multitude of bushing issues. The first one would be the strut rod bushing. Following those are UCA and LCA bushings, engine and tranny mounts. Rotate the wheels around and see if there is any change in vibration. LS's can be very sensitive to wheel balance issues, the slightest bit off is amplified when combined with worn bushings. 60km/h 45MPH is the typical speed this shows up.
Old 11-09-12, 11:55 AM
dengman
dengman's Avatar
my engine mounts and trans mount need to be replace. I have a vibration above Xxxxrpm... I suggest strutrod bushings because u said felt during deceleration. But as RA40 said it could be any bushing.
Old 11-09-12, 06:54 PM
LScowboyLS
LScowboyLS's Avatar
hey RA40, what are the most common bushings to go bad in a 96 LS400?
Old 11-10-12, 01:00 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
single most common dead bushing is the front strut rod bushing.
second is probably the rear carrier arm bushing.
third is the UCA/LCA bushings
fourth would be the shock mounts themselves.
Old 11-10-12, 08:06 AM
billydpowe
billydpowe's Avatar
I agree with PD, but I would use a dial indicator on the wheel AND tire for radial runout, just to be sure.
Old 11-11-12, 12:13 AM
shorestyle
shorestyle's Avatar
Also the car pulls to the right when braking. The vibration seems to go away at highway speeds and when driving in heavy traffic.
On that diagram, which is the strut rod? (48660, 48670?) and the bushing? (48574?)
Old 11-11-12, 01:13 AM
PureDrifter
BahHumBug
that picture is for '95+ cars, not your '89-94
Old 11-11-12, 07:09 AM
billydpowe
billydpowe's Avatar
sorry PD, I went back and corrected it...
Old 11-11-12, 01:15 PM
PureDrifter
BahHumBug
and that picture doesnt show the strut rod bushing
Old 11-12-12, 01:18 PM
timmy0tool
timmy0tool's Avatar
is this for UCF10 or UCF20 or for both?
Quick Reply: Having a weird vibration issue. Any ideas?
