Is there a scanner that the dealer only has?
Old 11-13-12, 06:10 AM
makecopies
makecopies's Avatar
Question Is there a scanner that the dealer only has?
Is there a scanner that the dealer only has? That only reads Lexus codes? kinda of like the BMW peake scanner only brings up BMW specific codes for our cars.
Old 11-13-12, 07:46 AM
billydpowe
billydpowe's Avatar
I think so called DLC3.... see pdf.
File Type: pdf
Old 11-13-12, 10:41 AM
IncgntoLex
IncgntoLex's Avatar
They do have a specific scanner. Just not called the DLC3. DLC3 is in reference to the Data Link Connector, most vehicles have several of these connection points and the number only designates which one.
Old 11-13-12, 11:13 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
dealers have a scan tool that will show extra information and allow for certain things to be written (CBEST settings and airbag/immob codes), but all basic troubleshooting codes will show up on your average OBDII scanner. You may need to look up manufacturer specific codes online if your scanner won't tell you what the code is for, but it should give you the code itself.
^above is for OBDII '95+ cars only.
Old 11-13-12, 11:31 AM
makecopies
makecopies's Avatar
The reason I asked because someone on one of my other forums offered to give it to me for the shipping price and he said it was a scanner that only the dealers have.
Old 11-13-12, 02:38 PM
billydpowe
billydpowe's Avatar
and here I was thinking I had helped this member out... the cbest was what I was referring to.
Old 11-13-12, 06:28 PM
PureDrifter
BahHumBug
unless it's a multi-thousand dollar Snap-on or equivalent reader, i doubt it.
but for the pprice of shipping you can't really go wrong now can you lol. my bets are it being a generic OBDII code reader though, unless you're very, very lucky.
Old 11-14-12, 09:45 AM
LScowboyLS
LScowboyLS's Avatar
As a former Lexus master technician, back in the day, I can tell you that the official factory scanner issued to us at the dealership (JM Lexus) was the Vetronix Mastertech
You can shop it hard on ebay and find these for sale for around $350 for the scanner + around $325 for the latest Toyota/Lexus/Scion firmware personality card 14.1a
I would choose this over the Snap-On as it will do more tests and retrieve more information as it is the factory Toyota tool.
You can also reflash the ECU with it!
Old 11-14-12, 05:00 PM
Lavrishevo
Lavrishevo's Avatar
Will it allow you to advance timing and change fuel / air ratio?
Old 11-14-12, 11:08 PM
nthach
nthach's Avatar
Both the older Toyota/Bosch(who bought out Vetronix) scanner and the Snap-On/Denso Techstream can tap into the TDCL on the older LS and the DLC3/OBD-II port. The newer scanner supports CAN natively and supports the newest cars.
goosenotes
Maintenance
06-12-17 08:23 AM
Lesly1
09-20-16 06:22 PM
ccorogers
07-17-11 11:59 AM
4482
04-07-09 06:17 PM
dusouth
12-10-08 03:09 PM
Quick Reply: Is there a scanner that the dealer only has?
