ehh..cost of door lock actuator?
Guest
Posts: n/a
blah..friggin car..
Anyone know how much it is (i used search in the LS forum) for a new rear left side door actuator? The rear door cannot be locked unless you pull the handle out and push the lock manually. This sucks for security, because it gets unlocked all the time, and my rear door is open to the public if a certain curious individual wanted to open it. I tried messing with it when I had the door panel off, but I had no clue what to do. Dealer time I guess..
How about the lock unit for the outside of the driver side? Where you put your key in- The key sometimes sticks and unlocks all the doors instead of just the driver. The handle is nowhere near 'soft' anymore when you pull it, you can feel it kind of grinding when you pull up.
So yah, cost of either of these pieces? plus install?
Talk about going back in time!!
I am now having this problem with my rear passenger door.
Mine is now manual lock & unlock. pain in the a**!!
Anyone have a solution??
