Last edit by: IB Advertising
Browse all: Lexus IS Engine and Powertrain Guides
- Lexus: Why Won't My Lexus Go into Gear?
Guide to diagnose trouble and recommended solutions
91' LS400 won't get out of first gear HELP!!!
Ok so here's where we're at currently.
Last night I popped my ecu out to show you some stuff going on inside.
This morning I went back and hooked it back up to the car because I found a way to run diagnostics on my transmission: http://soarercentral.com/sc-forum/me.../1113/932.html
So I used a paper clip and started looking for the blinking O/D OFF to see how many times it would blink to pick up a code and it would just blink 2 times every 1 second (which means the system is running normal). So I was stumped again. Then I thought, well I basically reset the ecu the moment I took it out from my car last night. So maybe I should run the car for a bit and wait for the ecu to scan on its own for codes. So then I decided to go for a stroll expecting to be stuck in first gear.... IT SHIFTS NOW! It's running top notch again, and even smoother now after those two oil changes No check engine lights or blinking O/D OFF (even though I never had those to begin with)
So now I'm just creeped out. I mean, re-setting the ECU is what obviously fixed this. So I think it's safe to say that maybe I should just replace the capacitors and never look back?
BTW thanks for continuously checking back on this thread. You really did help out a bunch.
yes! - this tells you that the transmission controller of your ECU is having issues, and those issues are going to be capacitor issues!
your transmission control is giving you a warning "Fix me!"
you need to go ahead and make sure which capacitors you have *before you order them* by visual inspection, as every ECU is different, my list per year range is the typical, not absolute.
if you leave the glove box out, it only tastes a couple of minutes to remount the ECU so you can use the car while the caps are being shipped
Ok so exact symptoms now come and go. It was driving fine for a good 30 miles and it started again. Well now my main focus is to get this ECU serviced. I personally am not that strong with soldering/electronics. I noticed driftmotion offers a service to replace capacitors on 1UZ ECUs for 80 bucks. Can I trust them? My buddy has purchased numerous 1JZ parts from these guys so I know they're good in their sales but just wanna make sure they're good with electronics.
But I did check the harness by the trunk hinge:
I peeled back a few sections of the harness on the driver side from the trunk hinge, and nothing that I can spot. I mean, I can remove the entire loom but for the most part, I didn't see any abnormalities. Interestingly enough though, I did/still have the warning light on the dash for a "bulb out". I never really check to see if I actually DO have a blub out. But like I mentioned earlier, the bad harness symptoms seem to include erratic dash lights, weird braking, and shifter indicator lights being all wacky on cluster. Mine all light up fine. So I never got any input from you guys on driftmotion. Should I go with them? I would ship my ECU out today.
PS- Is it normal that my REVERSE light lights up every time I hit the brakes?
you don't know any men or women who are adept at soldering?
of maybe an electronics assembly place firm in an industrial park could recommend someone
WOAH. Ok. This car is nuts.
Check out what I found:
Black and white wire was completely snap in half. Black wire was on it's way.
So I repaired those 2 wires and went for a test drive....
No more reverse light light iluminating when I brake!
I also use to sense that the car would shake (getting rear ended feeling) when I would press on the brakes and it would down shift. Now that's also gone! Smooth like butter! I can even feel when it down shifts.
The indicator light for "bulb out" also went away!
AND ABOVE ALL, SHE NOW SHIFTS ALL THE WAY THROUGH! Drove it for like 30 miles and not a single hiccup!
I can't understand how some wires located in the trunk could cause so much drama. These cars are a bit complex. Coming from Nissans that is.
1993 LS400 not shifting out of first gear NEED HELP!!
Hey everyone, I’m new to the forum. I recently purchased my 1993 LS400 about a month ago. Everything has been awesome up until today. On my way home from work I noticed the car wasn’t running right. I looked down at my dash and saw the R was illuminated as well as the D while I was driving. Then I noticed it was revving at 5000rpm. So I pulled over put it in park and took the keys out, and the R was still illuminated until I opened the door. Now every time I start it up the R is constiently illuminated, and will not shift outa first gear.
if anyone has any idea what this could be. I would really appreciate it.
Thank you
Thank you
tyncobb
10-30-10 03:21 AM
josh4495
08-22-10 09:01 PM
