92 LS400 Battery Problems
Old 12-13-12, 11:15 AM
SSAstro
SSAstro's Avatar
Default 92 LS400 Battery Problems
we put in a brand new battery about 2 months old but it drained already. this is about the 3rd time it has happened. the charging system is good. no engine check light. any suggestion???
Old 12-13-12, 12:23 PM
Shiryo
Shiryo's Avatar
Might want to give PD More details... Aftermarket electronics? HIDs? Radio? Something is grounded bad and causing a voltage drain.
Old 12-13-12, 01:26 PM
LScowboyLS
LScowboyLS's Avatar
yes, you have a drain, assuming your alternator is charging correctly, and the vast majority of drains are from some type of aftermarket add-on, like Shiryo correctly pointed out, an aftermarket stereo, HID's, etc.
bone stock LS400's do not tend to have any drains
the first step is to put a voltmeter across the battery with the engine at idle, to verify alternator performance, you should have at least 13.1V at idle and at least 13.6V at 2500rpm
Quocsc400
SC- 1st Gen (1992-2000)
07-21-13 02:36 PM
DJRATEDR
28
10-10-11 08:38 PM
wolver1ne5
08-05-11 07:49 PM
BigBang
06-27-11 06:31 PM
Quick Reply: 92 LS400 Battery Problems
