Cigarette lighter
usually some kind of installation of some aftermarket something
if you have an aftermarket stereo, alarm system, HID's, etc (anything electronic that isn't stock) - check those circuits first!
Attached is a schematic diagram for 98-00 JDM Celsior. Probably your USM is mostly the same. The red lines are ACC lines and there are 3 fuses.
The chances are
1, an internal short circuit of the Ignition Switch between AM1 to pin 3
2, the internal short circuit at the Radio No.2 line equipments.
There are equipments that require both constant 12V and ACC 12V at Radio No.2 line. For example the radio / stereo needs constant 12V supply for the backup memory as well as ACC 12V. When something wrong happens in those or at some aftermarket equipments, there is a possibility that ACC and constant 12V are short circuited internally. When this happens, you can obtain 12V at cigar lighter lines. Removing the fuse Radio No.2 is a way to conform this. Is you cigar lighter still active when the fuse removed? If not, the Ignition Switch is not short circuited.
The chances are
johnls400
07-18-15 06:02 PM
ThomasGS4
08-15-11 09:55 PM
