Ecu question!!!!!!!95-96 ls
12-13-12 | 07:44 PM
Will a 95 ls400 ecu fit my 96 ls400? Thanks
12-14-12 | 12:19 AM
No
1995 uses Toyota p/n
89661-50220 or
89661-50221 or
89661-50223
NOTE: original California cars for 1995 use different numbers than these, so be careful that you know where your car was delivered when new.
your 1996 needs Toyota p/n:
89661-50302 or
89661-50303 or
89661-50304
and higher number are preferred, due to newer programming which eliminated stalling after high speed operation issue
my 96 uses 89661-50303 with new capacitors and is working very well.
12-14-12 | 04:11 AM
actually, they are interchangeable (ie will plug in and work) but aren't worth it as the '95 had a large recall due to an issue with stalling after prolonged highway driving.
12-14-12 | 06:59 PM
Damn, I need a new ECU.... Mine was never replaced. Ugh.... I wonder if the recall is still in place?
12-14-12 | 07:03 PM
I don't think the recall gets your ECU replaced, but it should definitely get it
reflashed with the latest programming, which was really the only change.
12-14-12 | 07:12 PM
Ok, I will call and get some info. Do you think I should replace all of the caps and then get it re-flashed?
12-14-12 | 07:25 PM
it doesn't matter which order you do it, they won't be opening the ECU to reflash it, so they won't know if it has ever been worked on.
12-14-12 | 08:56 PM
recall expired many years ago.
12-15-12 | 08:42 PM
lil tip i switched mine to from fed to cali emision and besides the dead cats no problems at all and throttle shock eliminated
12-16-12 | 02:07 AM
Thanks for clarifying, I had someone ask me the same question and I didn't know what to tell them, since I had some parts for sale.
lextout
12
09-09-17 02:00 PM
celsior20
13
07-05-17 08:53 PM
Stereorob
Florida Lexus Club
05-30-14 04:17 AM
Chefao
Performance & Maintenance
11-22-13 10:38 AM
2Darkness
03-21-12 08:24 PM
95 ,
96 ,
changed ,
communicate ,
computer ,
differant ,
ecu ,
entry ,
lexus ,
located ,
ls ,
ls400 ,
numbers ,
reflash ,
remote ,
replacement
