Replace/Clean Transmission Pan Oil Strainer?
Old 02-12-13, 10:52 PM
  #31
Yamae
Yamae's Avatar
Originally Posted by ls400geek
I wonder if the condition of the transmission screen (whether or not it is clogged up) can be easily seen with a borescope through the drain plug opening. I don't want to drop the pan if I don't have to. I assume it's the original 15 year old screen on it.
You will know how it is difficult / impossible to do what you are thinking of. The red part is the lower part of the strainer. The drain plug is located at right lower end.
The blue line indicates the ATF level after the drain bolt is removed. You will see still the ATF is remaining there. I had a bad experience with it. When I dropped the pan, it came down to my face. It was still hot and my face was burnt some. If I were a woman, I could not go out for a week or more after that. You should be very careful dropping the pan.
A650E transmission side view
Old 02-13-13, 07:16 PM
  #32
LScowboyLS
LScowboyLS's Avatar
yikes - that diagram makes me want to weld up a transmission pan shield!! - what if I hit something in the road or drove off a high curb!
Old 04-03-13, 01:43 PM
  #33
SpencerT
SpencerT's Avatar
on the trans pan, are the 2 bolts in the front corners longer than the others? I put the other 17 back in and the 2 bolts I had left wouldnt tighten
Old 04-03-13, 10:19 PM
  #34
PureDrifter
BahHumBug
PureDrifter's Avatar
'98-00 FSM only lists the one in the center of the rear edge as being different, not sure about '95-97 (different trans).
Old 11-13-13, 07:11 PM
  #35
PlotPoint
PlotPoint's Avatar
Thought I would post an update. The last time I had the car in the shop, they told me the transpan was 'seeping/leaking'. Yes, I just had that leaked 'fixed' not that many months ago, with FIPG, put in a new oil strainer, etc. I think the problem was the mechanic I chose, not the method. For what it's worth. I will never have anyone other than a highly trained (e.g., Lexus trained) mechanic work on my car ever again. Lesson learned.
Old 11-13-13, 07:17 PM
  #36
LScowboyLS
LScowboyLS's Avatar
FIPG is not a good mix with typical mechanics, I don't even trust myself doing it! - I use a Fel-Pro gasket, as does Yamae!
Old 11-13-13, 10:13 PM
  #37
valex
valex's Avatar
Default 1999 LS400 ATF drain bolt
I have a 99 LS and I have been draining about 2 qts every oil change, sometime more often. I have been reusing the drain bolt, didn't know I have to get a new one. Last time I drained and refilled, I felt the bolt wouldn't tighten, just keeps turning. Yesterday I tried taking it out for a drain and it wouldn't come out, just turns. What shall I do?
Old 11-13-13, 10:44 PM
  #38
Shmee
Shmee's Avatar
Probably have to order a new pan and bolt!
If it still seals you could always cheat and order a siphon transfer pump.... Not sure which costs less though....
Smart money is probably the pan and bolt!
Old 11-13-13, 11:27 PM
  #39
LScowboyLS
LScowboyLS's Avatar
Toyota designed the bolt to be disposable, to keep someone from ruining the pan by over-torquing it - you will have to drill it, and unless you are quite skilled and preferably have a lift, that will need to be done with the pan off of the car, so I would be locating the correct Fel-Pro pan gasket, and might as well put a genuine Toyota filter in there while you are at it!
gonna be very messy with a pan full of oil, so be careful
also be careful on the torquing of the pan bolts, it is only 5.5 ft-lbs torque and you need to use a torque wrench (preferably inch-pounds)
for future reference, replace both bolt and metal crush gasket at each drain & fill, they are only about $5 for the pair at the dealership
Old 11-14-13, 09:03 AM
  #40
valex
valex's Avatar
Thank you guys, will let you know how it goes.
Old 03-25-14, 07:22 AM
  #41
kayuwong
kayuwong's Avatar
Default Service manual said replace one particular bolt
I had put a new rubber gasket instead of ATV, I thought it would fix my leak, but leak remain the same amount. Opened up my service manual and said it need a new bolt for one particular bolt. So I loosed that one up and pry opened out the lock washer plus adding one new washer, tighten that up and no more leak. I know it sounds weird, but it works according to the service manual. That bolt is located at the top second one near the drive shaft. Hope this inform will help you all to solve the mysterious leak.
Old 03-25-14, 10:07 AM
  #42
LScowboyLS
LScowboyLS's Avatar
can you provide a diagram or photo of the location of the bolt in question - or at least the page number and manual number of where this is discussed?
Old 03-25-14, 11:15 AM
  #43
kayuwong
kayuwong's Avatar
Default Lexus ls400 2000 service manual
Volume 2 under AT-12 , there is 19 bolts, there are 3 bolts next to the drain plug, the one in the middle need to be replaced a new one according to factory manual. I didn't replace it, just pry open the flat lock washer make it back to spec. I added an extra washer to it. No more leak afterward, I guess there is the difference between factory service and DIY job. I can't figure why tho, may be that bolt is longer or shorter. I don't wanna take out all 19 bolts and compare. Good idea to play around that bolt before re do the gasket again.
Old 03-25-14, 11:21 AM
  #44
kayuwong
kayuwong's Avatar
Default Picture
See bolt in the middle next to drain plug
Attached Thumbnails Replace/Clean Transmission Pan Oil Strainer?-image.jpg
Old 03-25-14, 12:02 PM
  #45
kayuwong
kayuwong's Avatar
After reading what pure drifter post, I think that bolt may be shorter than the others, by having a longer one in that spot, pan can't be complete sealed. I bet no one will pay attention to the length of each bolt when removing the pan. Lexus is smart by doing this dirty trick, they want you to have it done by dealership.
Sactolex
SC- 1st Gen (1992-2000)
13
12-18-15 06:00 PM
JasonARGY
11-18-15 06:36 PM
LexChamp
07-16-07 06:48 PM
jasonmo
01-27-05 11:11 AM
GOLDSc300
Maintenance
01-10-04 01:43 PM
Quick Reply: Replace/Clean Transmission Pan Oil Strainer?
