Front LBJ nut hitting rotor?!
Or upper ball joints...
Think about it, if a balljoints separates from the knuckle or LCA... What's holding that of the suspension to the car and from falling out?
Scary I know but if you have a partially separated LBJ, you are a short drive away from the pictures above!
Yeah, well we've replaced the UCAs yesterday, i've already replaced all my inner and outer tie rods. strut rod bushings have been replaced, wheel bearings have been replaced.
So I've noticed since the day after I replaced the Driver's Lower Control arm, somehow the LBJ is still tapping the rotor, just with dips or when there is load on that corner.
I have been inspecting the LCA replacement and it doesn't appear to be bent, it was purchased used. Looking back at the photos, i'm wondering if my red-line markers indicate the arm is also bent. I should probably compare it to the passenger side.
I was thinking of putting in a brand new OEM LCA however, the only thing i'm worried about, is that it might not be the LCA.
The car's body is straight so I don't know what else it could be.
All brand new and OEM.
Picture in this thread shows the arm and new LBJ (bottom)
https://www.clublexus.com/forums/7661832-post17.html
