Last edit by: IB Advertising
Browse all: Exterior Guides
- Why is My Power Window Not Working?
Guide to diagnose trouble and recommended solutions
power window issues
Yamae,
Would it be practical to take a mulitplex network door computer or individual door computer from a salvaged LS400 and just swap them out? Would that involve any mismatched programming or would it be "plug and play?"
If I am not good at doing things like those, I just will replace the master door computer finding it at a junk yard. Make sure that you try to find one which has a same part number.
Drivers window goes up/down, then stops immediately
First off, thanks for accepting my request to join the club. So, my 96 ls400 driverside window goes up/dwn but then stops after 2sec. Then i gotta help it up the rest of the way. I took motor off regulator to see if just getting stuck, but nothing seems to be in its way. Motor seems weak, like it spins but then slows to a stop. I dont know anything bout electronic but im a quick learner if understood, all kinds of advice is greatly appreciated. Wanted to know more before spending money on things not needed
sounds like you pissed it off when you put the camry switch in it. yes they look VERY close but they are not the same. if a bunch of other stuff went out too, id check your fuses.
the drivers master window switch issues are VERY common. seems to be unique to the 1995s only. mine has always been intermittent and everyone else ive ever known with a 95 has the same issues. however, the driver window will always work, and the other 3 windows work fine if operated one at a time, from the other door switches, but sounds like you have something else going on...
ogaustin
06-28-16 10:19 PM
