Suggestions. .. Two tear oil pan bolts don't tighten.
Old 01-12-13, 07:10 AM
sha4000
sha4000's Avatar
Default Suggestions. .. Two tear oil pan bolts don't tighten.
I've actually had this problem for a while. The two bolts in the rear of the oil pan just keep spinning so the oil pan doesn't seal. This has caused a leak bit over time but it has sealed itself over more time to the point that it's not a problem and i keep a jug of oil in the trunk. Now I'm ready to flush the cooling system plus the oil so i figure this its a good time to fix things. I'm thinking a regular tap set should collect this or some kind of insert. What do you guys think? Should i attempt this or just find a shop this take care of it? Money and time is an issue for now since I'm in the process of a major make over for the car. All responses are welcome.
Old 01-12-13, 07:14 AM
sam12345
sam12345's Avatar
Helicoil...................................... ...........
Old 01-12-13, 02:25 PM
sha4000
sha4000's Avatar
That looks promising I'll look it up. Thx
Old 01-12-13, 10:27 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
you're talking about the lower oil pan right? I would pull the bolts to see if it's the bolts that are stripped or the aluminum upper oil pan (probably the pan). If you're comfortable with installing a helicoil then it's a good way to go, otherwise you may need a shop, since if you screw it up too bad and need to replace the upper oil pan, the motor or subframe need to come out.
Old 01-13-13, 07:04 AM
sha4000
sha4000's Avatar
You are correct PD it is the upper oil pan and i do know any screw up in there well cost major money. I'm comfortable trying the inserts but would just let a shop do it as long as its not a ridiculous price.
joaqin
GX - 1st Gen (2003-2009)
01-30-16 07:21 PM
propcop
08-05-15 03:00 AM
lex92sc300
SC- 1st Gen (1992-2000)
08-28-11 05:42 PM
jbobst
RX - 1st Gen (1999-2003)
19
02-02-10 12:43 AM
Lyrical
CL of Southern California
04-09-08 08:14 AM
Quick Reply: Suggestions. .. Two tear oil pan bolts don't tighten.
