Smoke at WOT kickdown -
01-15-13, 12:25 PM
This morning, I was sitting at 30mph at 1800rpm, and had to do a instant -kick-in-the-pants WOT kickdown.
The car hit 4k and sped away. I noticed a small plume of smoke in the rearview mirror.
What could it be? Unburnt gas, or....? No other times do I have smoke.
01-15-13, 03:04 PM
BahHumBug
01-15-13, 03:23 PM
did you happen to see what color it was? See if you can reproduce it and also take a close look at the exhaust when starting it up in the morning.
01-15-13, 03:36 PM
i've seem many cars show large plumes of smoke when at WOT, mostly all black from burning fuel.
white = water indicating a head gasket failing, and blue = oil indicating seals/piston.
01-16-13, 11:08 AM
Looked like white or blue smoke, but when the car does cold starts, no smoke at all.
It was low 30's when this happened yesterday.
01-16-13, 01:52 PM
If it's white check your power steering idle up valve or remove it and bypass.
01-17-13, 12:26 AM
BahHumBug
that cold and it was probably just condensation from the water in the exhaust, you should be seeing it on a lot of other cars at that time too, esp. at night when the exhaust gets illuminated by headlights.
lexus-is2
01-28-14 11:46 AM
BrownGuy
SC- 1st Gen (1992-2000)
24
10-08-10 02:41 PM
Sirius2ten
18
02-07-08 12:51 PM
bbroom
07-23-07 08:47 PM
vsd
GS - 1st Gen (1993-1997)
03-12-05 10:52 PM
