97 LS400 emblem removal
Old 01-26-13, 01:36 PM
deckerson5
deckerson5's Avatar
Default 97 LS400 emblem removal
I want to take off the Lexus and LS400 emblems and just leave the center "L". are there posts in the emblems or just tape?
Old 01-26-13, 02:50 PM
johnnyg66
johnnyg66's Avatar
Both. Pry up carefully.
Old 01-26-13, 06:30 PM
Dranom
Dranom's Avatar
theres a bunch of holes behind it
Old 01-26-13, 07:22 PM
Mugen_1
Mugen_1's Avatar
There are two prongs behind the "LS, two behind the "400" and two behind "Lexus" (one on the L and one on the S). I've got the ones I removed sitting next to me ha. For what it's worth, there are two on the "L" as well.
Easiest removal is to get some adhesive remover that won't damage your paint, then take a piece of dental floss and floss it between the glue and the paint. Don't use paint scrapers or anything hard plastic as this can scratch the paint.
Old 01-26-13, 08:18 PM
RA40
Super Moderator
RA40's Avatar
One of my gripes, every Toyota I've bought has the emblem registration holes. Makes the shaved emblem routine $.
Old 01-26-13, 08:36 PM
Sc0pe
Sc0pe's Avatar
Well, from what I've heard, you can use a heat gun around the edges until you're able to wiggle the emblem(s) around and after that, use the dental floss/fishing line and use that to "cut" through the double sided tape, and finish off by removing the extra adhesive residue with some 3M Adhesive Remover and a rag.
Old 01-27-13, 12:29 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
don't worry about messing up your paint when you take them off, you'll be needing to weld the post holes in and repaint the trunk to make it look right anyways lol.
Old 01-28-13, 05:22 AM
j2b4o
j2b4o's Avatar
Anyone know if there are holes beneath the L emblem on the first gen??
(Sorry for the hijack)
Old 01-28-13, 05:30 AM
ls400geek
ls400geek's Avatar
Ok now you guys are scaring me. I was considering taking off my silver emblems and having them plated gold, but now I am affraid to!
Old 01-28-13, 05:35 AM
johnnyg66
johnnyg66's Avatar
Yes there are holes behind both emblems. When i swapped trunk lids the emblems off the old trunk came off very easy. There are grommets that go into the holes that help the pegs on back of emblems stay in place.
Geek, you can but gold plated ones on line if you break the other other ones.
Old 01-28-13, 10:02 AM
timmy0tool
timmy0tool's Avatar
yes they have holes behind them! replaced gold emblems for silver!
used the 3M stripe off wheel to remove the old adhesive. prior to that, i used fishing wire to remove the old emblems.
hoosier58
SC- 1st Gen (1992-2000)
19
09-18-13 05:39 PM
deekim
01-10-10 12:03 PM
javila32
12
06-02-09 04:32 PM
ssmoked
10-01-08 09:43 AM
mjames08
12
02-26-02 02:27 AM
Quick Reply: 97 LS400 emblem removal
