I wanna change my 99LS400 tail lights to Red or white to replace the ugly yellow
My 99LS 400 has this ugly yellow for signals on the tail lights , I saw the same lexus as mine with clear ones .. now is there any good sources on this forum that sells red or white tail lights that replaces the yellow signals?
There is an LED setup from Japan. It sometimes pops up on Ebay and sells for around 650.00. Also Jin from Kyeoi-USA and I just did a red vynil cover on the orange. You cant even tell with out looking at it. I just recently took it off to be replaced as it was lifting. Let me see if I can find a picture of it
![](http://kyoei-usa.com/blog/wp-content/uploads/2011/11/sn5-1024x682.jpg)
![](http://www.canibeat.com/wp-content/uploads/2010/07/az_ls400_7.jpg)
This was my LS400 the day I bought it (w/ orange tails 2 years ago)
![](http://img.photobucket.com/albums/v165/DJSurfer616/lex2.jpg)
And this is when I put red vinyl over them on a couple of weeks after I bought it
![](http://img.photobucket.com/albums/v165/DJSurfer616/lexdump5.jpg)
And today with that same red vinyl I put on 2 1/2 years ago:
![](http://img.photobucket.com/albums/v165/DJSurfer616/LSASS2_zps11b52942.jpg)
If done right, it will last for a very very long time without dulling the clarity of the vinyl!
lol the corners aren't yellow, they're orange/amber. but anyways, you can slap some transparent red vinyl on there which is the best and cheapest option. or you can have them sprayed with red taillight spray. i prefer the vinyl method since you can easily remove it whenever you want vs. having to spray down some brake cleaner or liquids in order to take off the spray.
here's how mine looks like with red vinyl.
![](http://img341.imageshack.us/img341/5319/img0401i.jpg)
a couple buddies i did:
![](http://img29.imageshack.us/img29/4342/mg9528.jpg)
![](http://www.stancenation.com/wp-content/uploads/2012/06/168.jpg)
btw, there are different kinds of red transparent vinyl, some being darker than others (depends where you get them from) so you should be careful when shopping around for them cause i've seen some with dark red vinyl and it's very obvious and doesn't look right/match with the rest of the red on the tails but as you can tell, mine are fine.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
BUT.. if you want to get LED tails for the 98-00, keep in mind that the 95-97 aren't interchangeable with the 98-00, 95-97 tails are shorter in length for the inners. the best price i've seen for the 98-00 LED tails is roughly $600, so good luck with that.
