Cleaning TB on 98 -- Drive by Wire question
Old 02-07-13, 04:08 PM
ls400geek
ls400geek's Avatar
Default Cleaning TB on 98 -- Drive by Wire question
I'd like to clean my TB without taking it off the intake manifold if possible. Can this be done on a 98 or does it require me taking it off the intake manifold since it is drive by wire?
Old 02-07-13, 04:30 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
you can try to clean it but you won't be able to clean the inner side of the butterfly so it won't be nearly as effective as it would if you took it off.
Old 02-11-13, 07:15 AM
McPierson
McPierson's Avatar
You can clean in inside of the blades. Just pull the blade open. I think the problem isn't the blades it's the body where the blades can make contact if the carbon is built up too much. Then it sticks which sucks for mileage and driving smoothness.
ssms91
09-29-15 08:03 AM
CJLennon
09-25-11 08:33 PM
cgreenberg
30
07-19-10 12:32 PM
Ryeno
07-17-09 11:29 PM
Dennis-C
Performance
03-16-04 11:19 PM
Quick Reply: Cleaning TB on 98 -- Drive by Wire question
