$20 Borescope from eBay -- any good?
Old 02-11-13, 08:12 PM
ls400geek
ls400geek's Avatar
Default $20 Borescope from eBay -- any good?
Has anyone tried one of these $20 (or so) USB borescopes? They any good? Do they light up?
E.g., it would be useful to have one for inspecting for potential sludge build up in a car that you are planning to purchase--just open the oil cap and push it in and see
Old 02-12-13, 04:02 AM
Kansas
Kansas's Avatar
What can you lose for $20 but my borescope was about $300.
Old 02-12-13, 05:32 AM
Yamae
Yamae's Avatar
I don't know which one you are referring to but I bought this one about 2 years ago paying about $40 at the Amazon.
I found it not OK to use for my purpose which was to see the cylinder because the diameter was a bit bigger than the spark plug hole. So I decided to remove the aluminum cover which is surrounding the C-MOS camera unit. After that, I could use it to see the cylinder.
But there was a noise problem and I could not see things well enough. Since I am mostly OK to deal with electronics affairs and I did some modifications. I added a home made ripple rejection filter to the DC-DC converter in the camera unit. The result is not good enough but I can now see the cylinder as below.
These are not Celsior's but my Honda's which is my sub car.
Old 02-12-13, 11:57 AM
LScowboyLS
LScowboyLS's Avatar
very cool!
Old 02-12-13, 02:24 PM
timmy0tool
timmy0tool's Avatar
so the scope records onto a storage unit built in and you can download it via USB? very cool!
Old 02-12-13, 07:27 PM
Yamae
Yamae's Avatar
It is just like a USB camera. You can use it as a cam-corder with a PC. The digital video signal is sent from the camera unit to the USB port. All you need is to record the signal to a hard disk drive in your laptop.
If the S/N (Signal to Noise ratio) were improved, this could be very convenient and useful. The original cheap design and the poor performance were not good enough but adding a filter improved the noise floor to minimize about 10dB or more. But there still remains some noise as you can recognize horizontal lines there. Adding 1 more filter can improve the S/N some more but the size of the head unit (camera unit) becomes too big to use at the spark plug hole. I am now trying to make a small but a better filter.
5gears-IS
Great Deals
02-17-17 02:52 PM
alfaromeo3
RC F (2015-present)
14
08-26-16 04:46 AM
AznRacer
Wheels and Tires Classifieds
10-13-09 08:29 PM
Quick Reply: $20 Borescope from eBay -- any good?
