90 ls400 issues
Old 02-12-13, 05:13 PM
ef9racer
ef9racer's Avatar
Default 90 ls400 issues
last night I was driving along then I lost all power items. radio, gauges, heat, and drive lights.
the things I did today was test ALL relays, fuses, grounds, and cleaned the battery terminals and any discolored open connectors. all of the fuses are good, all relays are good, I also checked the alt and when everything works it charges at 14v but when everything didn't work the car dies when the battery is disconnected and it show a voltage drop to 12v so that means that the alt is not charging. I disabled my ps so no its not leaking on to the alt.
my question is there any other reason for the lost of all powered items.
Old 02-13-13, 01:12 AM
LScowboyLS
LScowboyLS's Avatar
sounds like a bad battery, replace it with a new one and then recheck the voltage with car on and then with car off
should be greater than 13.6V on and 12.5V off
Old 02-13-13, 06:31 AM
ef9racer
ef9racer's Avatar
Thanks But I forgot to say I also had the battery tested. and it passed as being good.
Old 02-13-13, 06:35 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
check the alternator ground, if it's corroded or internally broken it'll randomly kill the car.
Old 02-13-13, 06:47 AM
ef9racer
ef9racer's Avatar
where is the location of the ground.
Old 02-13-13, 11:41 AM
PureDrifter
BahHumBug
thick cable attached to a nut and bolt on the alternator itself.
Old 02-13-13, 05:15 PM
Yamae
Yamae's Avatar
Sounds like a slip ring issue to me.
Old 02-17-13, 03:17 PM
ef9racer
ef9racer's Avatar
now when I hit a bump it will shut all powered items and once I hit another they all turn back on.
Old 02-17-13, 05:24 PM
oldskewel
oldskewel's Avatar
I have had a battery with an intermittent fault before. Only took a year to trace that one down. If you've got a spare battery (or swapping with another of your cars), that might help to isolate it and really verify that the battery is good.
Old 02-17-13, 07:12 PM
LScowboyLS
LScowboyLS's Avatar
loose ground connection or loose connection at battery terminals, fuse links, fuse boxes
this should not be that hard to find, actually, be glad it comes and goes with vibration, this makes it much easier to locate - have someone sit in car and watch powered items, while you go under hood and start whackin stuff with a soft mallet that could be suspect - i.e. ground strap connections, battery cables, connections etc.
UNCJD
11-23-16 12:21 PM
rogerowens
07-12-16 04:14 AM
chnco
09-29-15 04:26 PM
Formrobots
14
02-14-11 01:44 AM
mersad23
12-02-10 06:49 PM
Quick Reply: 90 ls400 issues
