Installed some 10in subs
Old 02-20-13, 03:09 PM
usoff89
usoff89's Avatar
Default Installed some 10in subs
Ok, so I'm done with the install of the new box. It's just a small sealed box with two 10's. I have them mounted in the rear deck. I'm going to add two 6x9's on each side also running off a small amp. I still need to build a mesh cover to go over the subs. But here are some updated pictures with the new finished box. I'm rocking these old kickers until I get some funds together for some newer subs.
File Type: bmp
File Type: bmp
File Type: bmp
File Type: bmp
File Type: bmp
Old 02-20-13, 03:13 PM
dengman
dengman's Avatar
i would go for some 10s designed for smaller space.. so the box isnt has big.
Old 02-20-13, 03:41 PM
usoff89
usoff89's Avatar
I'm still trying to decide on which subs I'm going to get. That will determine if I make a smaller box or not. If the darn gas tank wasn't in the trunk, it would have so much more space.
Old 02-20-13, 10:56 PM
YoshiMan
YoshiMan's Avatar
the question i think anybody should ask before posting any negative comments, is how does it sound?
Old 02-21-13, 12:04 AM
PK_Celsior
PK_Celsior's Avatar
i ended up going for one big 15" woofer tuned to 32hz. I might build another box for it so i can have the port pointing upward towards the original subwoofer hole in the rear deck
Old 02-21-13, 12:59 PM
usoff89
usoff89's Avatar
The amp in the picture wasn't doing the job. I just picked up a 1500w amp and now they hit pretty good. I don't know if the door speakers are stock or not (never had the panels off), but it sounds pretty darn good for the money I have in it.
Used everything (for now)
JVC headunit $60
2 Kicker 10's and box $35
new used 1500w amp $50
Honestly these cars are so well insulated from the factory. I am maxing out the headunit, but it still sounds perfectly clear. With the doors shut and windows up, you would never guess how loud it is inside the car. Then open a door, and BAM it sounds like you are stepping into a concert. lol. I'm not a pro, but I'm very happy with the way it sounds. It has lots of bass on the songs it should, and sounds awesome on the rock songs too.
If I keep that box and the location of it, I should have just enough room underneath it to fit the air tank....
Old 02-21-13, 01:51 PM
djsurfer
djsurfer's Avatar
Wow I never thought Id see a box mounted up like that! I have the same size box with 10s on the floor facing the trunk and they slap. Ive had Alpine Type R speaker/components that Ive been meaning to put on the Lexus and Ive been waiting for almost 3 years for these 21 year old speakers to blow and nothing, still sound great so until then it looks like ill be too lazy to cut up the individual speaker boxes in each door to fit the bigger alpine ones...
Old 02-21-13, 03:36 PM
usoff89
usoff89's Avatar
Yeah, I'm going to design some kind of mount to where I can easily take the sub box out if I need to, like for a family trip or something. I'm thinking of some kind of sliding racks so you can just slide the box into place. The racks could hold the box's weight and then just have a bolt on each side to keep it from going anywhere. But, it's all still just ideas for now.
I'm planning on putting two 6x9's on each side of the box with a small amp running them. I ran two sets of RCA's just so I could do that later down the road. When it's finished I will be making some sort of cover (maybe speaker mesh) to go over the whole thing, and also I want to have access panels to the coilovers for easy adjustment. When you look inside the car with the cover on it, you will only see a smooth surface all the way across the deck lid. Sound will flow threw, but you won't see them.
I'm surprised no one has asked what is holding the trunk lid up.....
Old 02-21-13, 03:44 PM
1sWt2GS
1sWt2GS's Avatar
why do you have it hanging and not just place it on the floor?
Old 02-21-13, 03:54 PM
usoff89
usoff89's Avatar
Well, the main reason is to have easy acces to the spar tire well. And for bag setup coming soon, I needed the space. On top of that, I like the idea of having the subs pretty much in the cabin of the car. I'm not an expert nor do I have any scientific proof, but I think it sounds much louder and cleaner in the car with them up on the rear deck lid.
Old 02-21-13, 04:47 PM
Real671
Real671's Avatar
That's how my old setup was I was running a jl 8w7 wit a 500/1 slash series amp
Old 02-21-13, 05:27 PM
usoff89
usoff89's Avatar
Thats a clean setup! Is it ported into the car up top?
Old 02-21-13, 05:36 PM
Real671
Real671's Avatar
Yea I removed the stock 8 and it's ported into the rear but I ended up taking that whole setup out starting from scratch with a bigger sub
Old 02-22-13, 02:55 PM
usoff89
usoff89's Avatar
Added a few more pictures. I made some brackets for the struts, and welded them to the car. Worked out pretty good, and lifts the trunk very nicely.
Old 02-22-13, 05:01 PM
1sWt2GS
1sWt2GS's Avatar
i see
function > form.
Quick Reply: Installed some 10in subs
