Brake light on hard braking ?
I just bought a 95 ls400 about 2 weeks ago , Ive noticed if I come up on some stopped traffic a little too quick if I brake hard the brake light comes on for a second then shuts off , never comes on other than that , at first thought it might be fluid but the fluid is totally fine , not going anywhere not low ect .. just wondering if this is a wear indicator or something to that nature , if not what could it be ??
Any advice ?
Thanks in Advance =)
Any advice ?
Hmm this one is a large rectangle havent seen a circle one lol , the fluid is right up to the fill line , would have wondered if it was air in the lines or something but the brakes work great , no spongyness nothing , they stop great as well .
On the 95's, the wear indicator is on the lower right hand side, the EBrake and brake trouble light are combined together on one light on the lower left.
The brake fluid level sensor might be sticking/bad. also check the EBrake pedal and see if the switch is sticking too. should be easy to spot, it will be the single item on the assembly with wiring
Cruisin101
01-23-18 01:16 PM
