ls400/celsior airbag suspension question
I have the standard airbag suspension setup in my 89 toyota celsior, but the bags appear to be new. Im wondering if theres any way to adjust the height even further to lower it a bit more. I have a aftermarket height controller in the car.
I read somewhere on each corner of the car theres a height sensor, and if you wind the rod out, it makes the car jack itself higher, so im assuming if you wind it in, it would make the car believe its too high and drop it.
Has anyone had any experience in upgrading valves and valve line size on standard setup to make it a bit quicker, I heard the standard lines are 3mm in diameter.
Or does anyone have an experience with lowering the standard bags in a different way, through a sensor, valve etc.
Thanks.
Thanks.
400, air, airbag, bag, celsior, height, lexus, ls, ls400, maintenance, modifications, sensor, slam, standard, suspension
