Please help - Stuttering engine
Could a bad ECU cause the car to shift hard into drive or reverse?
a high idle, say 1200rpm or higher can also give a hard shift into drive or reverse, as can solenoid issues
Well, I think I may have found the issue. I found some wires behind the serpentine belt that have been rubbing against it. If anybody knows what these two wires are for, please let me know if this could be the issue. I'm hopefully gonna have the time to fix this tomorrow. Car has been sitting at work for about a week now.
already fixed today, thanks for the input and advice. the two wires went into the engine block and looked like they went to a coil on the other end.
Posted from ClubLexus.com App for Android
wrogers
04-24-08 06:27 PM
