Replacing Parking Brake Shoes
Evening all,
I'm a new owner in need!
I need to change the parking/emergency/hand brake shoes - does anyone know of a tutorial?
Thanks
Thanks
Parking shoes barely ever wear. They are used when the car is parked so there isnt a lot of friction going on. I would assume they are the same as every other drum and that removal is fairly straight foward. Pull the rotors off and take a look.
Yea, are you sure you need new shoes? It only engages when the ebrake is applied. Maybe you can adjust it but i don't think you'll need to replace it unless you're 200k + in mileage and the ebrake is always adjusted firm or applied most of the time when driving. Then again you would also know that the ebrake is applied and hinder MPG.
