UCF10 Sputtering/surging & low power
All,
So I had a no start issues and in my troubles I replaced in this order
Fuel Filter (no help)
Fuel Pump (no help)
ECU (car started after this)
Since the ECU replacement, the car has a little sputter and is surging at idle. The idle does not jump but is jerky when you slow down to stop.
Additionally, there is an intermittent loss of power. Sometimes I have to floor it to get moving and other times it works like normal. On the instances where there is no power, the engine is slightly jerky/surgy
Fuel Pump (no help)
Engine Coolant Temperature Sensor
clean MAF with compressed air and/or chamois cloth
clean throttle body
fix capacitors in ECU
clean throttle body
