I'm looking at getting a set of spacers for my temp wheel setup to get it a little more flush. Just curious about the max size spacer that is safe to run on the factory studs? The wheels I have now have a very weak offset, and I figured some spacers would help out a little.
It actually depends on the wheels you are running as some have thicker mounting points than others. Basically you want to have at LEAST 3-5 turns or more to be sure it won't back off (i generally recco 5-7).
Generally speaking a 3mm is safe, but you should always check thread engagement.
I see what your saying PD, I'll have to check the thickness of the wheel itself first.
