Aftermarket steering wheel thread!
#46
By chance you could make another dash table and ship it to Washington djsurfer?
#47
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
#49
Finally had some time to mess with the cruise control setup. I took it all apart and mounted the factory lever just under the steering wheel. It was actaully really easy. It's just three wires that I had to spice together. Then i just drilled a few little holes in the bottom plastic cover, and wrapped two black zip ties around it to hold it in place.
It works just like normal, and I can easily use it right threw the wheel. If your not looking for it you really dont notice it's there either. Now just to figure out how to get the horn working without having a wire getting wrapped up when you turn the wheel. I might just put a button some where, if I cant come up with a easy solution.
SQ-LS
25
08-26-09 12:01 PM
houstonnw
12
06-09-04 05:45 PM
mayandoom
15
08-29-03 02:21 PM
