Quick Release Horn Button
Old 04-09-13, 02:39 PM
djsurfer
djsurfer's Avatar
Default Quick Release Horn Button
It has been a couple of months now without my horn. Having done a quick release install on my Type R and being very simple to wire a spring loaded push button to work as a horn. Now with my 92 LS it isn't so simple and I am quite unsure of how to wire the push button I am planning on mounting to the side of the plastic shroud surrounding the steering column. Any body else do this for the LS and which wires specifically were grounded (if it is the same system used by Honda) to have the horn going again. I am tired of people cutting me off and me having to resort to other ways to attract their attention. Thanks in advance!!!!
Old 04-09-13, 03:40 PM
djsurfer
djsurfer's Avatar
Never mind, I did some tinkering and found the wire that needs to be grounded between the harness and the button. I will provide pictures and a how to on how to do this.
Old 04-09-13, 03:50 PM
usoff89
usoff89's Avatar
I'll let you do the work..... again. lol. Post the details on this. I would like to also get my horn working.
Old 04-09-13, 05:44 PM
djsurfer
djsurfer's Avatar
I'm in the middle of it ill post it up tonight or tommorow morning. Its quite simple just need to know which is the horn plug on the harness connector but with a simple wire trace to the stock steering wheel revealed the answer.
Old 04-09-13, 06:18 PM
YoshiMan
YoshiMan's Avatar
Horn broken? Watch for finger!
Old 04-09-13, 10:26 PM
djsurfer
djsurfer's Avatar
No broken horn, just had it uninstalled because of quick release set up. Took a lot of pictures. Will provide how to tommorow.
Old 04-09-13, 10:35 PM
1sWt2GS
1sWt2GS's Avatar
What steering wheel did you go with? Wanna see how it looks
Old 04-10-13, 01:02 PM
usoff89
usoff89's Avatar
He has a thread about his wheel setup. Looks pretty good, IMO.
Old 04-10-13, 01:24 PM
djsurfer
djsurfer's Avatar
Im running this set-up...
Old 04-10-13, 03:16 PM
djMaru
djMaru's Avatar
wow nice! steering wheel it looks good.
Old 04-11-13, 07:31 AM
TaffyK20si
TaffyK20si's Avatar
I did this with my Grip Royal steering wheel and NRG quick release a while back. Just pinned in to the wire that actuated the horn (not sure which) and ran it to a paper clip that I secured behind the short hub. Works like a charm.
fperron
10-05-17 07:40 AM
TeddyKei
11-10-06 11:13 PM
golfproatl
09-01-06 08:14 PM
K-Bud
GX - 1st Gen (2003-2009)
02-26-06 09:43 AM
Steve Barnes
21
02-22-02 02:32 PM
Quick Reply: Quick Release Horn Button
