Power tilt-away repair.. "How to" tutorial
#31
Glad it's fixed! My '99" "Cloud9" tilt was fine but my telescoping quit. So I took apart the column casing, set up the tilt the way I liked, and pulled the harness plug directly under the column in effect disabling both features. For me it worked without any programming involvement. Eventually I will take apart the telescoping motor and attempt repair.
As I read your other posts, I could easily find that you are a guy who is quite skilled. I'd like to know what you found trying to repair the motor.
#32
It seems no one has successfully ventured down the path to fix the 99-2000 steering column motor issue. Probably because Lexus changed from common brush-style motors to fancy brushless PCM driven electronically controlled units. Much more difficult for mere mortals, like us, to troubleshoot. Can't just supply 12v. to them to see if they work, because that's not what they need. Therefore, nobody can say whether these issues are mechanical (binding), electronic ( ie. motor ecu), or power supply issues. AFIK, Billy is the only one who paid the Big $$$ to have new motors installed in his/wifes '99 a few years back, but since then, they too, have again failed. I can't think of any other (widely-experienced) problem in our cars, that has evaded a reasonable DIY solution for all these years. Yep, my 99 has it too.
Steve
Steve
#33
Steve
Steve
wander
09-18-16 06:53 PM
billydpowe
08-06-11 01:10 PM
willcrets
01-29-11 10:17 PM
