anyone seen a GT style LS?
Old 05-17-13, 01:28 PM
  #31
OKSTANCE
OKSTANCE's Avatar
im just guna weld mine with a plate..my last welded diff i dailyed lasted about 6 months without the plate ha
Old 05-17-13, 02:19 PM
  #32
VanCityLS4
VanCityLS4's Avatar
PD - it's out of a 98' TT 6spd. I'm surprised the forum has come this far without anyone doing this swap & documenting it. I drive aggressively & a LSD is the only thing missing from the equation.
Old 05-17-13, 04:51 PM
  #33
PureDrifter
BahHumBug
PureDrifter's Avatar
Unfortunately that won't work for you. The 6spd diffs in the US/Canada had 220mm ring gears vs. 200mm ring gears for the turbo auto/all NA cars. The case is physically different and the axles won't bolt up properly either.
SC/GS/LS (98+ at least, up to ~'05-07ish dependng) had 200mm ring gears of the same series. they aren't directly compatible but close.
If i end up biting the bullet and ordering what I want, i'll document it.
Old 05-17-13, 05:12 PM
  #34
usoff89
usoff89's Avatar
Originally Posted by PureDrifter
was it out of a TT- 6 spd or auto? Th 6spd diffs were a whole different case/ring gear size. Not all TT diffs were LSDs either.
Keep an eye on my sig and you'll see something soon enough
Speaking of your sig......
Look I did it too! Any pictures of your supra? I've been wanting to get an 89 now for some time.
Old 05-17-13, 10:17 PM
  #35
PureDrifter
BahHumBug
it's waiting for a new drivetrain since the old one grenaded lol. 1UZ is very likely.
Old 05-18-13, 09:18 AM
  #36
Twista4004
Twista4004's Avatar
1UZ FTW I'm looking to drop a high rev 1UZ in a 240 and make that the go-fast while I make the LS my Super Presidential.
Old 05-18-13, 09:40 AM
  #37
VanCityLS4
VanCityLS4's Avatar
PD - so your saying auto TT & naturally aspirated have the 200mm ring gear if they were ordered with LSD.
Old 05-18-13, 01:32 PM
  #38
OKSTANCE
OKSTANCE's Avatar
im REALLY digging this! now if i could only see some shots of this sliding haha
http://www.stancenation.com/2012/04/...-toyota-crown/
Old 05-18-13, 01:37 PM
  #39
bdan
bdan's Avatar
so buy one?
They have them for LS's?
Old 05-18-13, 03:48 PM
  #40
PureDrifter
BahHumBug
for north american mkiv supras at least:
-all naturally aspirated (5spd manual and automatic) cars had 200mm ring gears and cases
-all turbo AUTOMATIC only cars had 200mm ring gears and cases
-all turbo 6-speed (V16x) cars had 220mm ring gears and cases.
the LS (98-00) has the same sized 200mm ring gear and a similar case, though the rear plates need to be swapped since the LS has mounting points in it.
Old 05-19-13, 11:48 AM
  #41
VanCityLS4
VanCityLS4's Avatar
Thanks.
I've found this info on Supraforums to get real specific. Maybe I should look on GS/SC forums for more swap ...
------->http://***********.com/mkiv-toyota-supra/supra-differential-compatibility-and-info!/<-------
Old 05-25-13, 08:10 AM
  #42
OKSTANCE
OKSTANCE's Avatar
oh and ONE thing i forgot! white letters on the tires ^_^
#dataggressiveaero
Old 08-20-13, 09:35 AM
  #43
OKSTANCE
OKSTANCE's Avatar
semi my inspiration for my build thus far
don't mind all the dirt =]
Old 12-11-13, 11:33 AM
  #44
Sc0pe
Sc0pe's Avatar
See if you can arrange to have a nice "Idlers" stencil made. White spray paint can and a bit of masking tape and voila!
Old 12-11-13, 01:33 PM
  #45
PureDrifter
BahHumBug
unless you fly your car to tokyo to take place in an IDLER's event, that has no place on your tires.
pure posing.
Quick Reply: anyone seen a GT style LS?
