Is sea 10w-30 oil ok for my 92 ls???
I just realized i put the wrong weight oil in my 92 ls it takes 5w-30 but i put 10w-30 i used gtx high milage sea 10w-30 part synthetic motor oil, should i be ok until the next oil chang or should i change it to the correct 5w-30 oil?
5w-30 is what the manufacturer says to use, so what do you think the answer should be...? The only reason you should up the oil weight is if your car leaks lots of oil, as a higher weight (thicker oil) will leak less. At my last job some junkers would come in that took 5w-20 from the factory but were up to 15w-40 which is diesel oil lol. Use 5w-30 and check your oil level at your next service and see if you need to up it to 10w-30. Otherwise just listen to your owner's manual/oil cap.
it would help us guide you to the optimal oil viscosity for your LS if you would tell us what city you are in (to look at the weather there) - and how much you burn between oil changes would be useful as well.
10W-30 is actually better for hot Georgia than 5-30W, but either one will work
I would suggest using a full synthetic next time such as Mobil 1, Pennzoil Platinum or Ultra, Valvoline SynPower, Castrol Edge, etc. and I would also drain and fill transmission with genuine Toyota T-IV fluid from the dealership (about 3 quarts) and use a new drain bolt and metal gasket (also from dealership)
The FRAM Ultra oil filter, p/n XG3614 is a pretty awesome oil filter and only about $8 at Wally World
T-IV fluid is about $5/quart and the drain plug & gasket are also about $5 for the set, at the Toyota dealer
I have switched numerous cars at varying mileage, a few north of 180k.
Never ever had a problem.
Thanks, j2b4o..
I was thinking of switching to synthetic on mine and just had not pulled the trigger... but will on the next oil change.
I know that filter choices can be very emotional for people and all of us have our favorite brands...but curious why we wouldn't just recommend the OEM? A case from Sewell prices out at $3.50 each... and that seems like a pretty good price to me. And they'll fit from 1990 up to 2006 LS models if I'm not mistaken.
Just curious.. Thanks for the info, though.
Fram is garbage but switching to synthetic is a no risk all benefit change. All the hype about not mixing and not switching is unfounded and has been proven wrong several times over. Switching is commonly blamed for finding leaks the Dino oils left clogged but in reality synthetic has a habbit of cleaning the gunk and than conditioning the seals cutting down on leaks and leaving a cleaner engine.
I generally use OEM denso from rockauto ~3.50$ ea. when I run out or forget to order more i go with a napa gold(wix) or the nicer carquest (also wix). I haven't found a local source for the denso that isn't a PIA to get to from my house.
