New wheels, questions about sizes.
Hi to all !
I'm planning to buy a new set of wheels in 19 inch. At this right moment I can get 2 sets in 19 inch, but I can't decide yet wich one I will buy.
I whould like to know from the wheel experts on this forum if those wheel will fit without any cutting/rolling fenders, and with what tyre size?
First set:
Team dynamics Equinox white edition.
5x114.3
Front 8,5 x 19 ET35
Rear 9.5 x 19 ET25
![](http://imageshack.us/a/img69/1266/teamdynamics.jpg)
Second set:
Genesis Strike
5x114.3
Front 8.5 x 19 ET35
Rear 10.5 x 19 ET23
![](http://imageshack.us/a/img24/7775/genesisau.jpg)
What do you guys think about the wheels?
Thanks in advance !
Dutchy.
First set:
5x114.3
Front 8,5 x 19 ET35
Rear 9.5 x 19 ET25
Second set:
Genesis Strike
5x114.3
Front 8.5 x 19 ET35
Rear 10.5 x 19 ET23
Thanks in advance !
Dutchy.
The first set of wheels I believe you should be fine but the second set your gonna need to roll the rear fenders and camber it out a little.
I'll give you an example this is before roll and 0 camber.
![](https://farm8.staticflickr.com/7052/6986305099_5fe170a631_z.jpg)
![](https://farm8.staticflickr.com/7192/6840186446_cf882d6d7b_z.jpg)
Lowering the car will naturally give the car camber but in the next few pics you will see I needed more camber and a roll
![](https://farm8.staticflickr.com/7264/7011060413_8246c9731b_c.jpg)
![](https://farm8.staticflickr.com/7220/7011058413_2949443991_c.jpg)
After a roll and some camber:
![](https://farm8.staticflickr.com/7053/6895212572_10c688fd1c_c.jpg)
It fits lol.......keep in mind that I have a 18x12 +7 in the rear.
I hope that helps answer your question.
Thanks for the info guys. Im planning to buy the first set.
The height is adjustable, i have a BC coilover set on the Celsior.
What tyre size's do you guys recommend? I think about 235/35 19 and 265/30 19
It's been a while, but i finally have them at home. The team dynamics were to much damaged, to much work so i got the second set of wheels.
![](http://imageshack.us/a/img703/5121/4e89.jpg)
![](http://imageshack.us/a/img600/5447/bmh4.jpg)
Sizes are 19x8.5 offset 35 19x10.5 offset 23, i really hope that i have enough with only a roll on the fenders. I dont want to camber them because it's my daily drive lol. Otherwise i will put the suspension up.
I really don't know wich tyre size i should use and what fits. What do you guys recommend? Front im guessing 235/35 19 and rear 255/30 19 ?
Thanks in advance.
Thanks in advance.
Not too low that's for sure. I don't mind to go a bit higher, i can't go inside amsterdam with this setup. I will get stuck somewhere for sure ! The exaust is pretty low on the LS400 ![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
![](http://imageshack.us/a/img845/3796/jw93.jpg)
5gears-IS
01-01-18 05:28 PM
